Moving up next year to a bigger normaly aspirated combo. My 347 combo has been a blast and very reliable. Its gone 11.2 at 130 mph in the quarter. That was in a full trim street chassis. 3200 pounds with me in it. 150 shot of nos.
Im going to be selling this in several ways. The whole drive train and nos system. (Engine, trans, exhaust, nos, electronics) could also break it up in those individual segments as well. Prefere to sell the whole combination.
Engine is a stock roller block. Bored and stroked with an Eagle forged crank, h beam rods, arp 2000 rod bolts, srp flat top pistons. Mains are girdled with a meling hv oil pump and moroso deep sump oil pan. Bottom end rebuit beginning of last season and completely gone through this season. 190 plus compression on all 8 cylinders and doesnt use any oil.
Top end consists of mls head gaskets, arp head studs, Edelbrock E-205 heads, Trick Flow stage 2 cam, Trick Flow push rods, Proform roller rockers (1.6 the better forged ones), FRPP valve covers, Professional Products polished Typhoon intake (full port and polish), summit 75mm and spacer, 30 lb injectors, a9l ecm, harness, summit billet efi distrbutor, Bbk high volume fuel rails and regulator. Sfi dampner, act ultra light weight billet flywheel. 160 amp alt, electric water pump.
10 to 1 compression. Setup very conservative.
Exhaust consists of Hooker 1 3/4 long tubes, 3" x pipe and turbo mufflers. Quiet enough to drive on the street.
Nitrous system is a custom setup from Induction Solutions. Annular nozzle. 6an feed, 4 an fuel. 15 lb bottle, heater, blow down tube, zex wot switch, leash electronics mini relay station, Induction solutions trash can nos solenoid, built in purge solenoid, standard fuel solenoid, aem induction pipe.
Transmission is a built up t5. Has a gforce 3rd gear, world class rebuild kit, just rebuilt this season. B&m billet shifter. Steel bearing retainer. Zoom stage 3 clutch.
im sure there is a ton I`m forgetting. For information or to setup an appointment to look at the setup call or text 5856891687. Greg. Everything is in the car, can be ran, driven etc. I have a bunch of pics I can text. Car is located in Bliss Ny. Wyoming county.
Also would consider selling the whole car too if the price was right. Would take 6k for the whole combo. If your want broken up would have to discuss the pricing.
