Old 05-20-2009   #1
Kylejb2663's Avatar
Liked: 34 times
NYM Trader: 2
Kylejb2663's Pictures
Kylejb2663's latest status update: Getting ready for Carlisle!
Default Parking Brake Adjustment
Guys,
Quick question for all of you.. I am anal about my car and like to perform the factory maintenance requirements all the time - I notice that they have something in there they says to "adjust the parking brake".
How is this done?
Thanks!
Kyle
Kylejb2663 is offline   Reply With Quote
Old 05-20-2009   #2
Wicked One's Avatar
Liked: 824 times
NYM Trader: 3
Default Re: Parking Brake Adjustment
Open the center console. In the front drivers side you will see an access door. Open her up and then you will see the adjustment nut. You can tighten or loosen the e brake from there, but I wuldn't touch it unless there is a problem.
Make sure to check out the NYM STORE.
Advertise On NYM!! details here
Wicked One is offline   Reply With Quote
Old 05-20-2009   #3
Kylejb2663's Avatar
Liked: 34 times
NYM Trader: 2
Got ya- It says it's part of there every 5,000 mile checkup - which I do oil changes at 3,000 just because I feel more comfortable with it... But, I have never adjusted that and it's never felt like it needed it so I was not sure if it's something that you guys do generally on your cars either.
Old 05-20-2009   #4
Wicked One's Avatar
Liked: 824 times
NYM Trader: 3
I have 9500 miles on my car. The only time I adjusted it was when it was hanging up when it was cold. Dealer did the TSB and then I took out some slack. That was it. So again, unless there is a problem with it not holding or not releasing all the way, leave it be, if it makes you feel better, you can give it a little lube.
Old 05-20-2009   #5
RideThePony2004's Avatar
Liked: 16 times
NYM Trader: 4
RideThePony2004's Pictures
RideThePony2004's latest status update: formally ponycrazy2002
how do u adjust on a 2002 mustang gt...i really need that done...
RideThePony2004 is offline   Reply With Quote
Old 05-20-2009   #6
Wicked One's Avatar
Liked: 824 times
NYM Trader: 3
Right under the handle.
Old 05-21-2009   #7
Senior Advisor
matt07gt's Avatar
Liked: 68 times
matt07gt's Pictures
matt07gt's latest status update: bummed....
Quote:
Find out in your own tech section
j/k
2007 Mustang GT FRPP 4.10's,JLT/Xcal2 93 Breenspeed tune, Pypes O/R H, Flowmaster American Thunder axle backs,Steeda Ultra-lites,20"Foose Nitrous rims
matt07gt is offline   Reply With Quote
Search this Thread:
Advanced Search
Parking Brake doesn't work Cory Matthews V6 Mustangs 2 04-15-2009 08:32 PM
brake issue?! BadA55f0Xxx 5.0 Mustangs 4 03-22-2009 09:32 AM
Brake Pads BubbaStanGT 1996 - 2004 6 03-15-2009 11:58 PM
E-Brake leftySVT281 Chassis / Suspension / Brakes 0 01-24-2009 04:47 AM
abs/brake RideThePony2004 1996 - 2004 19 01-17-2009 12:34 PM
