Like Tree12Likes
  • 3 Post By FangStang
  • 4 Post By FangStang
  • 1 Post By FangStang
Old 06-14-2015   #1
FangStang's Avatar
Liked: 169 times
FangStang's Pictures
FangStang's latest status update: Just purchased a Carjacket at carbag.com... sleeping bag for FANG this winter!
Default GO Caliper covers
Just "TRIED" my ten minute install of my new Grabber Orange caliper covers on my mustang...
Fronts went on in ten seconds! Faster than reading directions!
Backs are a whole different animal...
I had to remove the back wheels 4x to try to adjust the clips so that they wouldn't rub against the rotors...
Finally I went next door to my neighbor (a machinist by trade) and talked to him... He suggested turning down the rotors .040 to avoid them scraping the clips. Yes, I tried the stock rotors too...Both the aftermarket rotors and the stock rotors barely cleared the caliper carrier assembly. Wonder if it's just me, or does everyone else run into this crap???
Anyways... these are pics of the front and back with the calipers and the slotted/drilled rotors after installation... NO pics on car until rotors are turned... soon I hope!
SVTCruz, ROUSH 4 and greaser54 like this.
Grabber Orange 2007 GT 5-sp...Fang Performance Twister Special package. , 3.55:1 Limited Slip, Shaker 500, Predator tuned, C&L 95mm CAI, Borla X-pipe and cat-back exhaust. Hurst Comp Plus short throw shifter, 18x9 Black Bullitts with Nitto tires, "Stop the Hop" suspension package, suspension package, Koni Struts and shocks, SR lowering springs, SR double adjustable panhard bar, SR rear shock tower brace, 28800 miles
FangStang is offline   Reply With Quote
Old 06-15-2015   #2
NYC Regional Coordinator
MaximumRisk's Avatar
Liked: 281 times
NYM Trader: 6
MaximumRisk's Pictures
MaximumRisk's latest status update: sometimes i stop and ponder "is there more beyond awesome or is awesome as far as I am...
Default Re: GO Caliper covers
Is it possible to modify the rear cover instead of turning the rotor? Can you not grind some of the bracket off? By the way, Can you turn drilled rotors?
MaximumRisk is offline   Reply With Quote
Old 06-15-2015   #3
FangStang's Avatar
Liked: 169 times
It is the clip that fits in between the rotors edge and the caliper "holder". Imagine looking at the rotor sideways and seeing the edges and the cooling vanes. It's almost the same if the rotor had too big of a diameter. Neighbor said it would be better to take off some of the rotors edge, than to grind away at the bracket. The slide pin for the caliper goes directly through that area of the bracket, and he was worried about compromising the integrity of the bracket during the movement of the caliper.
He won't be turning the drilled face of the rotor, just the edge. And there is plenty that can be shaved off (no holes drilled at the very edge).
Other way to modify mounting is to drill and tap a hole at top of the bracket, and bolt directly to the carrier. (next step if this doesn't work!
Thanks for ideas...
EDIT: If you blow up the pic of the rear rotor, you can see around the outside edge of the rotor the area the pad doesn't make contact with... He'll shave a little around the rotor to give me a little more room! (I HOPE!)
Old 06-15-2015   #4
On Edge's Avatar
Liked: 1015 times
NYM Trader: 8
On Edge's latest status update: Happy New Year everyone !! It's going to be a great year !!
Hmmmm....I'm trying to understand the situation.
I've installed a bunch of these caliper covers with stock and aftermarket rotors.
Shouldn't be any problems.
Sometimes, you might have to carefully and slightly bend the tig welded cover brackets to the right angle.
Other than that, I've never had a problem.
Any other pics ?
AHRC CarShow-Fundraiser.
On Edge is offline   Reply With Quote
Old 06-15-2015   #5
On Edge's Avatar
Liked: 1015 times
NYM Trader: 8
Any other pics ?
Old 06-15-2015   #6
FangStang's Avatar
Liked: 169 times
Sprayed the brackets with a coat of High temp black paint. You can see the wear marks on the caliper carrier bracket where the edge of the rotor rubbed as it spins around. Third picture is where I filed the original scrape mark down with a file This is the only end of the four I filed. The other three I bent the clips to not make contact.. Compared the size of the two rotors (original and new) and they are the same...
GO Caliper covers-img_3583.jpg   GO Caliper covers-img_3584.jpg   GO Caliper covers-img_3585.jpg   GO Caliper covers-img_3587.jpg
Old 06-16-2015   #7
FangStang's Avatar
Liked: 169 times
Rotors were shaved down in diameter .050, and reinstalled with no scrapng issues!
Old 06-16-2015   #8
FangStang's Avatar
Liked: 169 times
Here they are...
GO Caliper covers-img_3596.jpg   GO Caliper covers-img_3597.jpg   GO Caliper covers-img_3598.jpg
Old 06-16-2015   #9
RETIRED 2018
ROUSH 4's Avatar
Liked: 6796 times
NYM Trader: 1
ROUSH 4's Pictures
ROUSH 4's latest status update: I have retired after many years in a long career. It was a difficult decision, but it was...
Cool Re: GO Caliper covers
Looks sweet, nice work.................Gives a nice look to those wheels.
** NYM DRIVE IN THEATRE **
ROUSH 4 is offline   Reply With Quote
Old 06-16-2015   #10
Super Moderator
ford20's Avatar
Liked: 1121 times
ford20's Pictures ford20's Garage
ford20's latest status update: 6 more days until a GT350 is revealed. There is so much want for that car.
Looking good!! Just keep an eye on the rotors for micro cracks by the drilled holes.
"Look up, get up, and don't ever give up.
― Michael Irvin
ford20 is offline   Reply With Quote
Old 06-16-2015   #11
FangStang's Avatar
Liked: 169 times
Default
Quote:
Thanks!
Posted via NYM Mobile
ROUSH 4 likes this.
Old 06-16-2015   #12
FangStang's Avatar
Liked: 169 times
Default
Quote:
Will do...kept the original rotors...just in case
Search this Thread:
Advanced Search
Caliper covers! Cuznlou727 Clubhouse 13 05-17-2013 08:23 PM
CALIPER BRAKE COVERS 10-12 mustang ROUSH 4 Chassis / Suspension / Brakes 0 10-01-2011 08:58 PM
FS- MGP Caliper covers - full set 93-04 Quick281 Chassis / Suspension / Brakes 16 08-27-2009 07:02 PM
S197 Caliper Covers Bangastang Bangastang 0 07-14-2009 03:55 PM
MGP Caliper Covers Bangastang Bangastang 0 07-09-2009 12:27 AM
