ENGINE
302 Roller V8 swap(Engine from a 94 Ford F150)
Weiand stealth intake
Holley 650 double pumper carb.rebuilt winter 2010-11
Holley fuel pressure regulator
factory electric fuel pump
Ford Racing valve covers
New 85 GT distributor
MSD distributor cap and rotor
MSD blaster 2 coil
GM Hei ignition module mod
Red Accel spark plug wires
factory mustang H.O. Headers
BBK 2.5” X-pipe
Mac pro-dumps 2.5” exhaust
3G alternator upgrade from 95 Ford mustang
Mercury cougar electric fan
Stock heads cleaned and checked out by machine shop
New head, intake, exhaust, oil pan, timing cover, and front and rear main seal gaskets
New water pump
New stock oil pump shimmed for better pressure
Reman. Starter from 94 F150(factory mini starter)
Transmission
T-5 5 speed manual
Pro 5.0 shifter
BBK adjustable clutch cable and quadrant with firewall adjuster
Aftermarket clutch
double hump transmission cross member
Suspension and Brakes
87-93 Mustang k-member
87-93 Mustang front rotors
Lincoln Mark VII calipers
94-95 Mustang brake booster
Lincoln Mark VII master cylinder
Wilwood adjustable proportioning valve
8.8 trac loc rear
3.73 gears
North Race Cars brake caliper brackets to use Turbo coupe disc brackets with factory width mustang axles
All new brake hoses fittings, calipers, pads, and rotors
Ford Racing differential cover
Tubular upper and lower control arms
Eibach lowering springs
replacement struts and shocks
Flaming River manual rack and pinion
Flaming River steering shaft
Steeda bump-steer kit
Maximum Motorsports caster camber plates
15x3.5”, 15x8” Weld wheels
New 165/80r15 front tires
B&M Line lock
New axle bearings and seals in rear
New wheel bearings in front
New u-joints in driveshaft
New rear output seal in transmission
Body and Interior
87-93 notchback quarter windows
Cervinis 3” fiberglass cowl hood
94 Mustang seats
3 spoke sport steering wheel
B and M pistol grip shifter with button for line lock
Kenwood CD player
Blaupunkt front speakers
Front brake rotors and hoses-1992 mustang gt Pads and calipers-Lincoln Mark VII LSC
Rear brake parts-1988 Ford Thunderbird Sport(2.3L turbo)
Engine Parts-1989 Mustang Gt
Also included
GT40P cylinder heads(may need machining)
83-84 Gts smoked headlight covers
rear dust shields and hardware for the disc brakes
factory rear quarter windows with the original sail panels
matching interior panels for the original windows
