So I tried taking off my coolant crossover tube plug the other day and ended up stripping it because it was on so tight. I was even using a cheater bar. Today I tried heating up the car to 180 degrees, releasing the pressure, and then using vice grips to get it off as recommended and that didnt work either and ended up just making more of a mess. Any suggestions? I already bought a new plug that you can use a socket with which will work much better. Now if I could get this thing off that would be greaaaaat..
Thanks!
Thanks!
