New York Mustangs - Forums » Non-specific Tech » Show Time » The best method for cleaning engine bay
Old 08-01-2009   #1
Wicked One's Avatar
Liked: 824 times
NYM Trader: 3
Default The best method for cleaning engine bay
I have done this and it works great.
Start engine, get it warm, not hot, just nice and warm. As an example if the car was fully cooled, run it for 5-8 minutes. Turn off engine.
Cover the alternator and air filter on your intake, Aluminum foil works great since the motor is warm. Everything else can be subject to light rinsing type spray, including the covered fuse panel. All of these areas get hit by water when driven in the rain.
Lightly spray entire engine bay with water from hose, you will see some light steaming, this is good.
Spray the entire engine bay, including firewall, plastic parts, metal parts, loom, coils and hoses with Simple Green. Set the hood down, not fully closed, just to it's safety catch point, and go find something else to do for 15 to 20 minutes. Let the simple green do it's work. Closing the hood let's the simple green interact with the steam you created with the warm motor. This loosens the tough stuff up so you don't have to work so hard in those heavily soiled areas.
Open hood, look for heavily soiled areas, wipe them with a rag, use more simple green if necessary. Rinse lightly with hose.
Spray entire engine bay with F-21, it foams, coat everything just like the simple green coating you did.
Close hood again, walk away for 10-20 minutes or until nearly all the foam has dissipated.
Open hood, Wipe up any areas that water settled and such. Wipe up any areas that the F-21 didn't dissipate on it's own.
You will note that the F-21 restores the black plastic parts to the same oem flat black color they were when new.. It leaves the paint shiney with no streaks on the fenders and fire wall. Best of all, it is not greasey to the touch.
Make sure to check out the NYM STORE.
Advertise On NYM!! details here
Wicked One is offline   Reply With Quote
Old 08-01-2009   #2
bobbyoooo's Avatar
Liked: 12 times
bobbyoooo's Pictures bobbyoooo's Garage
bobbyoooo's latest status update: shake and bake
Default Re: The best method for cleaning engine bay
very nice i gotta desperately clean my engine bay, what should i use to cover everything tho a towel or something that wont absorb the water like something plastic
2001 GT AUTO
"spending money that I don't have, to buy parts that I don't need, to impress people that I don't even know, who probably don't even care...."
bobbyoooo is offline   Reply With Quote
Old 08-01-2009   #3
Clubhouse Moderator
1990_LX's Avatar
Liked: 294 times
NYM Trader: 3
1990_LX's Garage
I usually just spray tire foam on it, let it sit, then buff any plastic surfaces with a rag but it never is really that dirty.
-1989 LX 5.0 - OBX LTs, VRS X pipe, MAC catback, TFS TW heads, .542/.563 cam, RPM Air Gap, 650 DP, SN95 brakes, UPR K Member, ect
-1995 3.8 - True duals, Flowmaster 40s, Hurst short throw, CAI, EGR/DPFE Delete (sold)
-1999 P71 Crown Vic Police Interceptor - CAI, 3.55s, MAC O/R Prochamber, Flowmaster 40s (Sold)
-2000 Exploder 5.0 AWD - Magnaflow Exhaust, CAI, 0.0000004 MPGs (DD)
1990_LX is offline   Reply With Quote
cleaning rims BadA55f0Xxx Show Time 6 03-17-2010 02:04 PM
Cleaning up joboo Wheels & Tires 14 05-23-2009 09:39 AM
Cleaning engine Wicked One Show Time 2 05-07-2009 08:27 PM
Cleaning rims joboo Wheels & Tires 2 03-21-2009 05:11 PM
Ford's Romeo Engine Plant Builds 10 Millionth Engine MineralGray02K Mustang News / Site News & Updates 0 02-19-2009 01:40 AM
