If interested in removing the ABS pump for 94-2004 Mustang GT/Cobra/Mach 1/V-6, let me know and I will machine the delete manifold to replace the ABS pump without having to re-plumb and flare lines. The factory ABS pump can be re-installed down the road if desired. THIS IS FOR OFF ROAD USE ONLY.
These manifolds are machined out of T-6061 aluminum and weigh (98-04) 0.3lbs. (94-97) 0.5lbs. The 98-04 ABS pump & bracket weighs 9.7lbs. The 94-97 ABS pump & bracket weighs 13.5 lbs.
ABS pump compared to the delete manifold:
Delete Manifold Installed:
ABS Delete Manifold Installed
ABS Pump Delete Brake Manifold - 2003-04 Mach 1 Registry Owners Club
94-04 Mustang ABS Delete Manifold - Modular Depot Forums
