Posted this car a few times now. It still sits. Need to get rid of it soon. It's got 21,000 orig. miles and is as straight as a pin. Never been hit and all the trim, moulding, is original perfect deep black. It has been in the pro sportsman class since 95' and was cert. 8.50-could easily be re-cert. could use a new tune as well. make offers. trades?---Possibly Sold Tomorrow
Engine-302/.30 over. Balanced and Blueprinted Sportsman Block. Block O-ringed
Paxton Novi 2000 Supercharger 21 Lbs of boost/boost recall gauge
Ross rods, Keith Black Pistons, Hardened Crankshaft, Clevite bearings
7 Qt Moroso Deep sump oil pan, Castrol synthetic 5w 50 oil + prolong used at all times
Milondon high volume oil pump
Ford EPEC high performance tunable computer
Tune Done by Larocca's in New Jersey, just before the entrance to Englishtown(Raceway Park)
Weldon fuel Pump, Paxton Filter and Housing(rated to 1000 HP)motor will not starve @ top end
3 Gallon Fuel cell and Boxed aluminum
Batter mounted in rear and boxed as well
Charging posts and covers mounted on rear bumper cover
N.H.R.A. Approved shutoff switch mounted on rear bumper
8.8 rear, Full spool, 3:55 gears, T/A girdle, upper and lower fully adjustable Control arms
Drive shaft safety loop
31 spline Motorsport axles
N.H.R.A. Approved long wheel studs
Maximum Motorsports Panhard bar installed after 4 wheel alignment
Centerline lite racing wheels(10”) with 3” skinnies and M/T drag 28/10
Line Lock mounted on shifter
Dynamic Mighty Mite C-4 Transmission with trans brake/matching 9” converter 4800 launch
Ultra Bell housing/ N.H.R.A. Approved shield
Trans cover/N.H.R.A. Approved
B+M cable shifter with reverse lockout/ Rm vb N.H.R.A. Approved
Electric fan
Moroso electric water pump
3 row Fluidyne radiator
MSD 7AL -2
Edelbrock Victor Junior Heads Fully ported and Polished 2.02/1.74 valves
Kenny Bell volt regulator and Boost a Pump
72 Lb injectors
Holley Systemax Intake/ fully ported and polished upper and lower with gasket matching
90mm Accu Fab throttle body
88mm Pro M mass air/extra large filter
4” intake tube from air cleaner from air cleaner to Blower
Heat sensor and gauge for the no. 7 cylinder to measure air fuel ratio
Cam- comp cam Custom grind done specifically for this car and custom tune
Full N.H.R.A. Certified Roll cage/6pt harness
MSD digital playback tach 5 ¼ face and full gauge cluster, fuel,oil,trans temp,fuel/air etc...
4” lift off cowl hood with safety clasps/ sheet metal rear wing
50/50-90/10 Lakewood drag shocks and struts Adjustable caster camber plates
MSD 2 step
MSD select RPM Module
Pro Dump exhaust
Professionally wired and all connections Silver soldered and fused
Electronics mounted on passengers floor
Still has power windows and locks
