Very clean and straight 8.8 rear axel. All parts in and on axel less then 500 miles.
Frpp 28 spline traction loc with carbon fiber clutches.
Frpp 4.10 gears installed. No noise whatsoever. That's with no sound deadening or carpet and a cage in the car. These are factory perfect.
Moser 5 lug c-clip axels 28 spline these are made for ssbc so no "m" logo on hub end. If you pull the axel moser is on them or you can call to verify.
Ssbc rear disk brakes.
Heavy duty shock mounts for coil over setup. Strange single adjustable.
Addco anti-sway bar. Axel mounted. Same as steeda. Addco makes them for steeda.
700 Obo without shocks and springs.
750 Obo with shocks.
800 Obo with complete shock spring and Coilover kit.
Call or text Greg at 585-689-1687
Still in car. Will pull at anytime.
