hey guys im building a engine new block stroker kit all forge, i'll be using a set of 98 svt heads with comp. cams and new valves and springs.
now my quiestions are 1) Do i need to used the stock intake with the deleded IMRC or can i used any intake to put this new engine on my 98 gt.
2) Will i need to replace the wiring and ECU or just flash the ECU to work with the 4 cams.
any opinion will be apreciate
thanks
thanks
