how much horses does a 347 usually put down
fiveohhfox Bronx Coordinator Jun 21, 2009 #1 Jun 21, 2009 #1 how much horses does a 347 usually put down
BlkStang89 Well-Known Member Jun 21, 2009 #2 Jun 21, 2009 #2 really depends on how much money u throw into em
1 1BIGMOFO Member Plus Jun 21, 2009 #3 Jun 21, 2009 #3 Its all about that $$$. You can cheap out and build a 347 stroker and get 300hp and you can spend $10K on one and get 500+. You get what you pay for...
DownSet4130 Let The Mods Start!!!! Jun 21, 2009 #4 Jun 21, 2009 #4 also depends what its built for... if you want it all motor or you plan on hitting it with boost or nitrous.
S SBF Coupe Member Jun 21, 2009 #6 Jun 21, 2009 #6 Na w/ junk parts mid 3's.... Good parts I would say 4ish. With the right parts and a power adder alot.
fiveohhfox Bronx Coordinator Jun 21, 2009 #7 Jun 21, 2009 #7 its got 351 heads cobra upper and lower manifold 30#injectors other b/s too
B BOSS10L Well-Known Member Jun 21, 2009 #9 Jun 21, 2009 #9 fiveohhfox said: its got 351 heads cobra upper and lower manifold 30#injectors other b/s too Click to expand... Just a rough guess, I'd say 300-350 at the crank. I know that's a wide swing, but there are so many variables to take into account.
stanginthe11s Well-Known Member Jun 22, 2009 #10 Jun 22, 2009 #10 a reasonable # is 1-1.2 hp per cube unless your parts are really bad
94Gt5.0 Well-Known Member Jun 22, 2009 #11 Jun 22, 2009 #11 Theres alot more to it than "what should XXX make". Whats the static C/R, cam specs, heads/CC's, Auto/5spd, etc etc.
BadA55f0Xxx Well-Known Member Jun 22, 2009 #12 Jun 22, 2009 #12 yea we need more stats on the setup to try and make tha kind of a prediction
Glueyes Member Plus Jun 22, 2009 #13 Jun 22, 2009 #13 There is allot of factors and variables that come into play.But if i had to guess 1500hp
