whats the best cam for a 347 stroker with 351 heads with 1.7 rockers
fiveohhfox Bronx Coordinator Jun 21, 2009 #1 Jun 21, 2009 #1 whats the best cam for a 347 stroker with 351 heads with 1.7 rockers
1 1BIGMOFO Member Plus Jun 21, 2009 #2 Jun 21, 2009 #2 I would call camshaft innovations and have them custom grind you one for what you want.
1 1BIGMOFO Member Plus Jun 21, 2009 #4 Jun 21, 2009 #4 You just want a cam out of the box? They have tons of them on Ebay. FRPP makes some nice out of the box cams..
fiveohhfox Bronx Coordinator Jun 21, 2009 #5 Jun 21, 2009 #5 yea i know but were trin 2 figure out the best 1 for the 347
svtnotch Well-Known Member Jun 21, 2009 #6 Jun 21, 2009 #6 I went with a custom cam from camshaft innovations for my 347. But if i went with a off the shelf cam i would got the comp cams XE282.
lonepalm aloha moloi`eheme Jun 21, 2009 #8 Jun 21, 2009 #8 fiveohhfox said: where can i find camshaft inovations? Click to expand... pretty easy http://www.camshaftinnovations.com/
94Gt5.0 Well-Known Member Jun 22, 2009 #9 Jun 22, 2009 #9 I would go with an out of the box TFS Stage 2 cam for your setup. Pretty cheap compared to getting a Curtis(or whoever) custom ground cam. Iirc, they are $150 or so, and its a great camshaft.
BadA55f0Xxx Well-Known Member Jun 22, 2009 #11 Jun 22, 2009 #11 i would look at summit and read the specs on the cams to see what would fit your setup the best especially if your goin specific top end or low end
Glueyes Member Plus Jun 22, 2009 #12 Jun 22, 2009 #12 StrongStang50 said: I would call camshaft innovations and have them custom grind you one for what you want. Click to expand... X2! If i had to do it all over again,i would have a custom cam done
