I'm trying to lower my mustang by cutting the coil springs and I need to know how much I should cut to lower about 1.5 inches. Has anyone done this? I'm trying to save time from having to continuously remove the springs to cut them bit by bit. Any help would be greatful
I went and looked at mine and I cut the top. Just make sure u cut the bigger end on the spring. There's a big end and a small end as far as coil wraps go
I believe on the cobra springs the top coil is flat and the bottom is normal. I'll start with the front because its more of a pain in the ass to get the springs out. since all I have to do is remove 2 blots to drop the back of the IRS and pop the springs out.
Ok whatever end is the same after cutting it will work example if I were to cut the bottom of my rear spring it wouldn't fit work on the saddle because it would be to big
So I cut the coils on the front of my car and I'm not to thrilled with the results. I still haven't cut the rears yet. I still have plenty of fender gap in the front
