just converted my efi to carb and even b4 i did every time i give it a lil rpm it pops out of the intake...and gets even worse as it goes up....i thought it was the computer swaped the nothing checked injectors they are ok even after i swapped it out to carb same shyt...someone plz help...
As much as I would like to think that its just a timing issue.... Sounds like there might be a bent valve, very loose rocker or a broken valve spring. Best thing to do is a leakdown test to make sure that is not something worse!
Ok so some crazy bullshit happen we pulled of the heads all is good what happen was a lifter bracket broke lifter turned and chewed the hell out of the cam!
I'll post pics shortly
