my abs is not working.the light is on and i tryed connecting my abs scan tool and its not responding. i use the abs scan tool on my boys car and its reponds.does any one know what the problem is?thanks
i did.the fuses are good,i tested all of them.i was looking on a website and i was told to look under the dash board in the drivers side.they said too look for a black box saying abs and there is a relay there.but i couldn't locate it.
the abs scan tool is already turn on before i hook it up at the port.it keeps telling me that its unable to connect.and keeps telling please check connections.
but when i hook it up to another car its works fine and is able to get the connections.i dont know why its not working with my stang?if anything im gonna wait until it gets warmer or the spring time to check the wiring of the abs and follow it and see if the cables are ok? i dont know what else to do?
i work at a shop and usually when it dosent respond to the car its always a fuse thats burnt.check the fuses again with the key on the ''on'' position.
