Current Bid: $200 NO RESERVE!!
Buy It Now: $13,900
Auction Ends: Nov 14
- Hp turbo kit with 60mm. t4 turbo (12 psi boost)
- hks ssqv blow off vavle, synapse 50mm. waste gate, big front mount intercooler
- 3" cold pipes, 3.5" downpipe to 3" Y into 3" dynomax bullets turned down exhaust
- The bottom end is mostly stock but very fresh (only 700 miles on the motor)
- forged pistons with twisted wedge valve cuts
- stock rods, crank, block
- stud girdle ties in the mains, canton 7qt oil pan
- comp custom turbo grind cam .569 lift , comp lifter, ford racing double roller timing set
- trick flow twisted wedge street heads (alluminum), trick flow 1.6 roller rockers and push rods
- edelbrock performer RPM 2 intake, 60 lb injectors
- msd digital 6
- world class T-5
- ford racing alluminum drive shaft
- 04 cobra carbon fiber 31 spline carier, motive 3.90 gear, moser axles (sn95 length) 5 lug conversion 4 wheel disc brakes
- steeda upper control arms and upr lowers
