1989 lx coupe (white) 2900
have my 89 coupe up for sale it is pretty stock for the most part just recently freshened up. the car has 5 lug conversion with 94-95 gt wheels with almost brand new goodyear tires has subframe connectors welded in. 3.73 gear. the interior is stock .has new black carpet installed by previous owner. ac is gone.the motor is from a 89 town car i put new oil pump in performace timing chain set ford racing f cam one piece molded rubber oil pan and valve cover gaskets new intake gaskets new pcv valve new plugs and wires.new altenator. new exhaust gaskets.has a c&l intake tube with brand new filter. it has 1 5/8 inch bbk longtubes with bbk h-pipe with moroso spriral flow mufflers with turn downs. new heater core just installed new wiper blades all glass intact car runs pretty good will soon be installing ac delete and the iac valve adjuster plate to correct idle warming up once warm though she will idle all day long at 800 rpm all new fluids ie.(tranny, oil, filter, antifreeze, p/s fluid). runs smooth and drives the same. please contact me at 256-647-1910 text or call anytime
