New York Mustangs - Forums » Mustang Specific Tech » 5.0 Mustangs » Wheel / Tire clearance -14" wheels to 16" Pony wheels
Old 05-04-2014   #1
Liked: 3 times
Default Wheel / Tire clearance -14" wheels to 16" Pony wheels
I have a 93 LX with 14" wheels and plan on putting on a set of 16" Pony wheels. From what I just read, the stock tire size on the GT or 5.0 using the 16" wheels were 225 55 16. However, I also read, the inner plastic fender skirt was reshaped on the GT and 5.0 to allow clearance for the larger wheels and tires. Now knowing this, it sounds like if I change the 14" wheels to the 16" wheels and use the standard tire size of 225 55 16, the tires will hit the wheel skirt since my LX does not have the reshaped wheel shirt since it came with 14" wheels. My question is, can I use a smaller tire on the 16" wheels to avoid an issue with the tires hitting the fender skirt?
JTFS is offline   Reply With Quote
Old 05-05-2014   #2
AdirondackFox08's Avatar
Liked: 491 times
AdirondackFox08's Pictures AdirondackFox08's Garage
AdirondackFox08's latest status update: Woohoo! Kevin Harvick and the #4 team won the race and the championship!!! What a great...
Default Re: Wheel / Tire clearance -14" wheels to 16" Pony wheels
You can go with a shorter tire, but you should be fine with what you have. The 91 to 93 mustangs had a little bit bigger of an opening for the wheel well to take care of the rubbing issues with the older models. Mine is a 90, and I'm running 245/45-16s on the front of my car. I did have 245/50-16s but when they wore out I was able to find something shorter and now the only time it rubs if I have the wheel cranked all the way, left or right, like if parking, but it rubs on the a arm instead. I try not to turn that sharp anyhow.
You should be able to search the tire diameter for the tire you have, or google a tire size calculator and find out what it is.
1990 Mustang GT - H/C/I, 3.73s, 292rwhp & 320rwtq
2009 Cobalt SS - G85 package, ZZP down pipe
1999 Polaris XC 700 - Winter toy
AdirondackFox08 is offline   Reply With Quote
Search this Thread:
Advanced Search
Tire Clearance going from 14" to 16" Pony Wheels JTFS 2.3L Mustangs 1 05-11-2014 02:38 PM
F/S NEW 17" x 8" Pony R wheels escogt Wheels & Tires 4 10-26-2012 05:24 PM
16" 4 lug pony wheels NickT02LS Wheels & Tires 4 03-07-2011 06:07 AM
16" Pony Wheels For Sale redlordamazon Wheels & Tires 5 11-28-2010 10:00 AM
set of 16" pony wheels with centers rustangg Wheels & Tires 2 07-16-2009 06:55 PM
