V6 speedos are 120 and GT's went to 150. Also, the tachs redline/end at different RPMs.
__________________ -1989 LX 5.0 - 5 speed, OBX long tubes, VRS SS X pipe, MAC catback, Eibach springs, SVE upper/lower control arms a bunch of polyurethane stuff, KYB shocks/struts, Edelbrock Performer intake, Holley 600
-1995 3.8 - True duals(divorced), Flowmaster 40s, Hurst short throw, CAI, EGR/DPFE Delete, 215k + mi(DD)
I was looking into getting a 2000 v6 and then swapping in a 4.6 so that I could save on insurance.
Yeas I know it would be easier to just get a v8, but i want to do the swap anyway, cause it will give me something to do.
My question here is do I really need to change the whole dash harness. Makes no sense to me.
I figured I would need a motor, tranny, driveshaft, rear end, and computer. No need for a whole dash.
If I can get a v8 donor car, that would make life so much easier I would figure.
lets see what i can remember
-engine
-tranny(if a stick)
-rearend
-springs
-radiator
-gauge cluster
-dash harness
-brake system(have to convert to hyrdaboost)
-ecu
missing some, give me a break, its early.
basically, a lot. unless you get a damn good deal, the swap really isnt worth it. If you just want something to do, you could blow the 6 and surpass what the swapped engine would be putting down(you never specified, so Im assuming its a basic 2v setup). unless you plan on a 4v, which drives up cost a fair bit
you wouldnt be able to inspect it,,ud have to sham a sticker,,,,u should just probly buy a v8,its easier and the time and money u could save by just buyin the v8 you could hook it up a bit,,,,never hook up a v6,might as well buy a honda,lol
If you dont have anything constructive to say, dont bother at all.
Im sure ford never wanted the essex V6's to get power, thats why they designed the block and crank to take at least 900hp from the factory. I say at least because thats where we are at now, and still have yet to break one from too much power. And dont let the GN guys here you say that...
He has a point though. Nothing wrong with the OP's idea, but he just brought up a good point.
Or the OP can TT the v6
It'd be a nice sleeper
__________________ Past: Michelle, 2006 Mustang GT, Legend Lime,1998 Cobra, Bright Atlantic Blue2007 Mustang GT, Tungsten Grey Present: 2013 Mustang GT, Gotta Have It Green Be sure to check out my Flickr photostream! Ryan's Flickr Photostream
Thanks guys for the help, I was thinking of building a bad ass v6 but who knows, still up in the air right now. Might drop 5k into a twin turbo set up for the 6, that would be a great sleeper.
something to think about- theres a lot of good setups right now. And Andy at TMA is making kits again, top notch parts from him. with the splitports, theres a lot of options- vortech, procharger, Eaton, Turbo, nitrous. all but the nitrous could be had for only a little more then the cost of swapping in a low-mile PI engine, with a more power
This is interesting, since the new 5.0 I been thinking how cool it be to drop it into my Pony Pkg car. A crate 5.0 seems well priced around $5k plus extra few thousand for the needed parts is a bargain compared to buying a whole new car. As for the inspection that doesn't seem like an obsticle as the point of the OBD II system is the verify the sensors are correctly working and the levels being reported aren't excessive.
__________________ "It's the Man, Not the Machine" - Chuck Yeager (Chuck Yeager's Air Combat) 2007 Mustang V6 Pony Pkg Auto - FRPP CAI w/ BAMA tunes 93 Performance tune, Stack Racing Strut Bar, AirAid Throttlebody Spacer, Sequential Taillight kit
ToDo - FRPP True dual Exhaust, 18" wheels GT500, 7.5 Trac Lok w/ 4.10 gears, maybe some other goodies...
Well it may seem like a bargin, you're overlooking the addition of supporting suspension, chassis, and brake set ups that come on the new 5.0s.
The 5.0 is around 430lbs If believe, close to the same as a 4.6 DOHC aluminum block motor. It would definitely be a nice potential swap once more parts are available like headers and what not. The tough thing right now is the power steering setup but I am guessing the hydro boost would work?
There is already a running/driving 5.0 Coyote powered foxbody done!
1993 Mustang LX 5.0 - Vortech Si-Trim, Edelbrock heads, Cobra intake, 60lbers, BA2400 meter, and a whole lot more... 2001 BMW 325i sedan - Alpine White 5spd, Sport Package,tan leather, 18" rims ~ Daily Driver
