New York Mustangs - Forums » Mustang Specific Tech » 5.0 Mustangs » t/b intake manifold question
Old 07-27-2012   #1
bkstang's Avatar
Liked: 3 times
bkstang's Pictures
Default t/b intake manifold question
hey all, i'm a newbie in the mustang world.. i have a 92 lx 5.0 5spd..
what are some of the upgrades i can do as far as throttle body and manifolds are concerned?? i'm not looking to race but want something a step up from stock. i'm having some idle issues,so before i spend $$$$ trying to fix it now i might as well look into upgrading it and eliminate the problem all together.
what are the advantages of the bigger t/b? ive seen that they come in different mm, what's the basic upgrade from stock?
can i put a setup from a cobra?
i know there probably silly questions, but i am new to the mustang world..
bkstang is offline   Reply With Quote
Old 07-27-2012   #2
BKD
BKD's Avatar
Liked: 243 times
BKD's Pictures BKD's Garage
BKD's latest status update: just hit $50 on a $2 scratch off ticket..............wooo hooo ...lol .
Default Re: t/b intake manifold question
>can i put a setup from a cobra? yes ...
stock t/b is 55 mm the cobra is 65 mm it will give you better throttle responce..
names ...BRIAN.
my DD
BKD is offline   Reply With Quote
Old 07-27-2012   #3
bkstang's Avatar
Liked: 3 times
bkstang's Pictures
thanks BKD, what else can use, if i don't use a cobra setup? can i use my stock intake manifold and just upgrade to the 65mm t/b? Do i need to upgrade my injectors as well??
Old 07-27-2012   #4
BKD
BKD's Avatar
Liked: 243 times
stock intake with 65 mm t/b sure .......not sure but i think after 75 mm t/b you need to upgrade the injectors ........but with a 65 your good to go with the stock 19 lbs....
names ...BRIAN.
my DD
Old 07-27-2012   #5
bkstang's Avatar
Liked: 3 times
bkstang's Pictures
ok thks for the info.. i'm gonna start looking for a setup then.. any brand in particular? bbk seems to be the norm i think.. i have bbk longtube headers on my car,i also have the cold air intake in the fenderwell also.. i would like to get the cobra manifold and the t/b as one whole package..oh well we shall see what happens.. thks again for the info greatly appreciated
Old 07-28-2012   #6
AdirondackFox08's Avatar
Liked: 328 times
AdirondackFox08's Pictures AdirondackFox08's Garage
AdirondackFox08's latest status update: Congrats to Harvick and the #29 Bud crew on the win tonight!
For the 5.0s, it seems that the biggest tb anyone goes with is 70mm, and you will also need the egr spacer of the same size. BBK throttle bodies tend to whistle, and a few people have had a screw from the blade come off and go through their engine, (not the norm, but it has happened.) TFS has their own tbs, never really heard anything bad about them. But really just changing the tb without the intake is not going to make much of a difference. No need to change injectors until you are making over 300 hp at the crank. Better mods would be gears, sub frame connectors, rear control arms, short throw shifter, some things like that. The heads are the biggest restriction on these engines, and to do a new h/c/i it takes a good chunk of cash.
Vanstrom Performance 308 short block
TFS TW 170s - Ported Explorer Intake
Comp Cams XE 270 HR 14 - 1.7 RRs
3.73s - MM FLSFCs - MM LCAs - UPR UCAs
Eibach pro kit springs - Strange 10 ways
Hurst short throw - Ram HDX - Shorties - O/R X pipe
SLP LM1s- and a few other things
AdirondackFox08 is offline   Reply With Quote
Old 07-28-2012   #7
Liked: 328 times
Also, what are your idle issues? Did you check for codes on it? Codes can still be present even if the cel doesn't come on.
Old 07-28-2012   #8
bkstang's Avatar
Liked: 3 times
bkstang's Pictures
here is what i have in the car.
373's
shortshifter
full length welded on subframe connectors
bbk ceramic long tube headers
small b cam(unknown brand)
i do have the check engine light on. i was told possibly cause of the cam.
i have not had the codes checked.
mas was cleaned and checked out.
my idle issue is that it stays high after i run for a bit and i come to a stop.
it will idle at about 15-1700 rpms. sometimes if i stab it,it will come down to right around 1000 but not always the case. recently tuned up,fuel filter replaced as well. i don't put cheap gas in it.
so i guess checking the codes is the next step..
Old 07-29-2012   #9
Liked: 328 times
Ah ok, so you have most of the bolt on stuff done then. Really a s/c, turbo, or h/c/i is the next step in power, but is definitely the most expensive too, lol. Doing the intake, new tb, and bigger maf will probably net you around 20-25 hp, but most people like to save up and do the whole top end at once.
Yeah I would check the codes and see what you get. It could be the iac, or the tps.
Search this Thread:
Advanced Search
Need 02 Intake Manifold 02minrlgrygt 1996 - 2004 6 06-05-2011 10:17 PM
BBK SSI Intake manifold ajros02 Air and Fuel System Related 7 02-22-2011 09:36 AM
5.0 Intake Manifold 1990_LX Windsor Motor Parts (5.0 / 5.8L engine parts) 0 01-24-2010 05:18 PM
89 5.0 Intake Manifold 1990_LX Windsor Motor Parts (5.0 / 5.8L engine parts) 2 01-15-2010 12:25 AM
p51 Intake Manifold jmansracerocket Windsor Motor Parts (5.0 / 5.8L engine parts) 2 04-25-2009 06:45 AM
