is it posiable to fix .....? the bottom is starting to go and idk what to do .:confused:
BKD Well-Known Member Nov 26, 2009 #1 Nov 26, 2009 #1 is it posiable to fix .....? the bottom is starting to go and idk what to do .
BKD Well-Known Member Nov 27, 2009 #2 Nov 27, 2009 #2 guess i should have worded it better ......the bottom of the strut towers are starting to rot out a little are they fixable ?
T TERROR Well-Known Member Nov 27, 2009 #3 Nov 27, 2009 #3 if your good with a welder they can be fixed depending on how bad they are.
BKD Well-Known Member Nov 27, 2009 #4 Nov 27, 2009 #4 thanks... they are not to bad but not to good ether .........
jkstang78 Well-Known Member Nov 27, 2009 #6 Nov 27, 2009 #6 How about you guys post some pics. So we can see how bad it is
