03-11-2009
#2 |
Wicked One's latest status update: Make sure brain is engaged before putting mouth into gear!! | I am in no way a tech, I just look around and see if I can find some useful info for you. I came accross this, it may or may not help, I am hoping that it does help.
Check Conditions: Vehicle speed has reached 1.5 kph (0.93 mph) or more at least once.
Under the closed loop idle speed control.
Engine coolant temperature is higher than 77°C (171°F).
Battery positive voltage is higher than 10 volts.
Barometric pressure is higher than 76 kPa (11 psi).
Intake air temperature is higher than -10°C (14°F).
60 seconds have elapsed from the start of the previous monitoring.
Target idle air control motor position is 0 steps.
Judgment Criteria: Actual idle speed has continued to be higher than the target idle speed by 200 r/min (300 r/min*) or more for 12 seconds . *: Specs in parentheses are applicable if the maximum air temperature during the previous operation was more than 45°C (113°F) .
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are): Idle air control motor failed.
Open or shorted idle air control motor circuit, or loose connector.
PCM failed.
PCM failed.
There is a troubleshooting procedure for checking the circuit and pinpointing the problem, but before doing that I would recommend cleaning the throttle body first. Many times a simple cleaning will eliminate this code.
If not, then the circuit will need to be checked and what is causing the problem repaired.
__________________ Make sure to check out the NYM STORE. Officer, I know I was going faster than 55MPH, but I wasn't going to be on the
road an hour. -- Steven Wright |
