Congrats to the Booger!!
This image has been resized. Click this bar to view the full image. The original image is sized 1024x768.
Chassis:
1984 Mustang GT Hatch
Complete UPR Chromoly Tubular front suspension and K-member
Strange 10 way adjustable front struts
UPR coil over kit & Eibach springs
UPR Billet Caster Camber Plates
UPR Torque link rear uppers w/ billet solid bushings
Wolf Racecraft offset adjustable rear lowers
UPR anti-roll bar
Mini-Tubbed
QA1 10 way adjustable rear coil overs
8.8 rear narrowed 5" total
Southern Outlaw Shop axle brace
33 spline Strange Hy-tuff axles with C-clip eliminators
Strange pro race spool
LPW differential cover with integral girdle
RJ Profab custom thru-floor subframe connectors
10 point cage by Vito Antonicelli Race Cars (certified to 8.50)
Simpson parachute and custom mount
5" lift off hood
10 Gallon RCI fuel cell (for engine)
1 Gallon RCI underhood fuel cell (for Nitrous)
Optima battery trunk mounted in Mororso battery box
RCI 5 point harness
Window net
Engine:
Ford Racing SVO R302 4 bolt main block
Canton Pro Pan
Eagle forged 3.4" stroke crank
Eagle forged 5.315" H-beam rods with ARP 2000 bolts
Custom Venolia nitrous pistons. 4.10 bore
Total cubes: 359 with 13.5:1 compression
Kennedy's Dynotune Custom solid roller cam
Comp cams solid roller lifters with link bars
Comp cams Magnum 1.6 ratio roller rocker
Comp Cams rocker stud girdle
Brodix Track 1 F 225 CNC Heads (Fully ported by Brodix)
2.10/1.60 valves
Titanium retainers and Locks
Billet Timing chain gears and true roller chain
Isky Valve springs
Barry Grant Gold Claw 825 “Drag Race” carb. Flows 1,000cfm
Ported Edelbrock Super Victor intake
Meziere 55gph electric water pump
Windage tray
Custom Accufab headers. 2” primaries, 3.5” collector
Dynomax bullet mufflers with turn downs
JW “the Wheel” internal balanced flexplate
BHJ SFI balancer
NOS Big Shot Plate System (Adjustable from 200-400hp)
Edelbrock 2” carb spacer
Powermaster 18:1 starter with inficlock.
Trans:
Dynamic Transmissions Mighty Mite M2 full roller C-4
Full manual reverse valve body with pro-tree brake
Ultimate Convertors 4,800rpm stall w/ anti-balloon plates
JW SFI Ultra Bell
Hughes SFI Scatter shield
SFI deep aluminum pan
Custom steel driveshaft with Strange Chromoly slip yoke
1350 U-joints
Mark Williams Billet pinion yoke
Electronics/Fuel System
MSD Digital 6
MSD Blaster SS Coil
Taylor Pro 10.4 mm wires
Innovate LM-2 Dual Channel A/F Ratio meter
Edelbrock Progressive Nitrous Controller
MSD Pro Billet Distributor
Auto Meter 5” Tach
All Auto-Meter Guages
Holley HP150 Fuel Pump (for engine)
Holley Black Pump (for Nitrous)
Holley bypass regulator for N2O
Holley regulator for engine
Complete fuel system in Russell braided line and AN fittings
Tires and Wheels
Moroso DS-2 26x4.5.15 Fronts
M/T 28x10.5Wx15 Rear slicks
Weld Prostar 15x3.5 Front wheels
Weld Prostar 15x10 Rear wheels
----------- Original Post ----------------
Here we go guys! 5 badass foxes, and only 1 winner among them!
Lets see those awesome foxbodies!
First up is D1Coupe, with his clean white notch
EHA Racing is in, with his 4eye!
look at that booger!
Teknik, with his 4eye...but not any 4eye, its a little more under the hood!
PrjctLxEnvy 's Sexy Green notch!
and last but definately not least, Vorstangs notch! if you havent seen this car in person, put it on your list!
And let the voting begin!
To our entrants, dont be afraid to post more pics with some specs on the rides!
good luck to everyone
