Okie dokie
Just fitted this kit on an 08 gt.50 bucks plus taxes and shipping ain't a bad deal in any ones book.
It comes in three parts, the block a bushing and a bolt.you reuse the nut from original link.
It doesn't change anything upstairs everything is done under the car. Just above where driveshaft meets the transmission.so take a flashlight with you.I would also advise you get the car as high as possible. Without dropping the drive shaft your gonna need a lot of room.your fingers are gonna have to be a bit dextrous.
It takes about an hour to fit and the instructions are idiot proof, something that would encourage me to buy other stuff from Saleen and attempt mod myself
I had to hammer the bolt into the bushing and then fit both together , the bushing is aluminum so I'm assuming it will loosen up a tad with use
It works great once you get the feel for it, it's stiff but positive.
Saleen claim 26% less throw it feels like more compared to what I considered an obscenely long throw on the stock set up
For 50 odd bucks and an hour of your time. I would say that this ain't a bad mod
