01-22-2010
#1 |
| Pump gas 565 cu in bbc 860 h-p/780 torque This is a high dollar engine I bought back out of my pro street car after I sold it the horse power above was with 110 fuel and only 20 horse power less with just 93 unleaded !! real numbers not a pumped up dyno in a 3350 pound car with turbo 400 best motor pass at 7000 rpm 8.90 @152 with a 200 plate 8.36 @163 mph I bought the complete bottom end back from my old car and bought the same set of AFR 335 head brand new,I have the nickerson dom. car from the combo as well the short has under 100 passes Dart 9.800 block 4.600 bore,callies crank,manley steel billet pro rods,CP pistons 0.43 rings,gas ported,Canton steel stroker pan,billet timing chain,6 inch fluidampeR,comp cams and this is where you will not believe 714/714 custom built roller with low 270/275 duration will idle 850-875 in gear !!!!!!!!!!!!
custom built 1050 h-p dominator carb with power valves,454R intake roof ported with cross over for water tapped in,new ARP pro head studs,csi reduction stater,manley c/moly push rods you need rocker gear,lifters,gaskets this is a high dollar engine with high power oh pump gas so it's not cheap to build just ad up the parts and hope to make the power $9000
__________________ 1968 Black Chevelle 565 bbc pump gas small tire 9 second street car/2008 Shelby GT500 red/black stripes 1000 H-P build |
