Old 06-02-2012   #1
Liked: 3 times
bmob's Pictures
bmob's latest status update: coffee
Default Pilot Bearing Help
Hi guys,
Its been a long while since I have posted last, went through some tough times with the mustang. The 2 piece flywheel wasn't liking the torque and the ring gear the starter engages kept coming loose. After 3 times removing the tranny I learned my lesson and had the machine permanently keep it in place . This time though, I looked into the end of my crank and my pilot bearing is shredded. I mean pins everywhere and the plastic casing was all messed up.
I have a 408w stroker (351w block bored and notched), and I need help to find a bearing that won't shit the bead, that is high quality, and that is reasonably affordable (though I am happy to pay for quality).
Does anyone have any experience with this? I could really use some advice and direction.
Thanks in advance!
bmob is offline   Reply With Quote
Old 06-02-2012   #2
ksteversn95's Avatar
Liked: 3 times
ksteversn95's Pictures ksteversn95's Garage
ksteversn95's latest status update: Has anyone heard anything on the mustang rally in norwich this year?
Default Re: Pilot Bearing Help
maybe have a brass bushing machined for it.
ksteversn95 is online now   Reply With Quote
Old 06-03-2012   #3
VIP / Donor
Michael B's Avatar
Liked: 47 times
Michael B's Pictures
Michael B's latest status update: I shared pics from WWP show on NY Mustangs Facebook page
You can buy solid bronze bushings. Measure your roller style to get the right one
Michael B is online now   Reply With Quote
Old 07-18-2012   #4
Liked: 3 times
bmob's Pictures
Quote:
The thing is, I think I may have made a mistake with the prior Pilot Bearing.
I froze the bearing to get it into the crank easier, and I used a large socket over the outside of it to hammer it into place. I did not measure the 'roller style' or input shaft diameter. Should I find a micrometer and measure my tranny's input shaft diameter?
Here is a link to the site of the bearing I had that shit the bed...
Ford Racing Mustang Roller Pilot Bearing (289, 302, 5.0L, 351) M-7600-A - Free Shipping!
I am having trouble finding a brass bearing that is solid instead of roller
Old 07-18-2012   #5
Formally Ihatemyliver
4eyedcoupe's Avatar
Liked: 91 times
NYM Trader: 3
4eyedcoupe's Pictures
4eyedcoupe's latest status update: I just saw an add for NYM on Craigslist....lol
I wouldn't freeze the next one. Should go in pretty easy with a little bit of help from a rubber mallet(don't need to beat it, just tap it gently until flush) and some bearing grease. I've done quite a few, getting out is the hard part, putting a new one in should be cake. Check this link out, it's instructions for installing a clutch but it also covers the pilot bearing.
How To Install A Spec Mustang Clutch - Installation Instructions at AmericanMuscle.com - Free Shipping!
4eyedcoupe is online now   Reply With Quote
Old 08-23-2012   #6
Liked: 3 times
bmob's Pictures
Thanks for all the help guys! Really do appreciate it!
Got the bearing out and the new one in (no freezing this time).
Let me tell you the horror story that removing that bearing was.
After removing the tranny, clutch, pressure plate and flywheel, I had exposed the torn up pilot bearing (the inner casing was shot, and the bearings were all in the back towards the crank). I did not have the pilot bearing puller tool, so I went the grease hydraulic route (see video here
) and that didn't work (put about 3 hours into trying that method).
The next day, I went to Advanced Auto and borrowed the bearing puller I needed. Sure enough, the bearing puller wasn't working either, it would just slip off the back and not grip.
I made my own puller after that, with 2 different size carriage bolts (one large, one medium) and used a socket, nut and washer to pull the bolts out from behind the bearing as I tightened the nut down. Broke the grade 8 bolts doing this.
After 11 hours messing with it, I got fed up enough to take an air dremmel to it. I wore the inside of the bearing down all the way to the crank, and split one side of it. The bearing collapsed a little, giving me the freedom to pull it out easier with the puller tool.
All in all it took 13 hours to get that bearing out, and If I ever have to deal with another pilot bearing again, it will be too soon!!!!
Old 08-23-2012   #7
FrostByte's Avatar
Liked: 508 times
FrostByte's Pictures FrostByte's Garage
FrostByte's latest status update: Check out the fireworks July 4th on lake George in the Adirondacks.....
MAKES YOU WANT TO THROW OR SMASH SOME THING VALUABLE DOSNT IT?! But hey, u won the battle!!!!!!
I just had an alternator that would only work when being fault tested, bish.
DSG 04" GT, 5 spd - P1SC Procharger 9 lbs - Anderson Power Pipe - 385 rwhp 329 rwtq - Dyno tuned by Performance Dyno - SLP LMII - Bassini X pipe - 3:73 FRRP - Eibach Pro-Kit - Nittos/ Staggerd on 18" GT500 Black chrome wheels - Seq turn - Steeda Short Shifter - Mach 1 grill delete & chin spoiler - Autometer boost & fuel press gauges - Shorty antenna - Smoked head & tail lights - 5K HIDs
Always remember you're unique, just like everyone else. Unknown
FrostByte is offline   Reply With Quote
Search this Thread:
Advanced Search
pinion bearing buck64 1996 - 2004 2 09-02-2011 09:34 PM
Pilot Ejects An Instant Before Jet Crash jkstang78 Misc. Pictures 9 07-24-2010 11:32 PM
18in Michelin pilot sport tires turbo05 Wheels & Tires 3 07-11-2010 05:54 PM
Front wheel bearing.... mustangfan V6 Mustangs 4 03-29-2010 04:02 PM
CCW's 505a's with michelin pilot sports Glueyes Wheels & Tires 12 05-04-2009 07:37 PM
