Can anyone give me some good advise, I read somewhere that you can tap into the PCM box behind the passanger side kick plate and hook up a manual switch to keep the radiator cooling fans running at high speed manually for cooling down that beast quicker. Does anyone have or know where I can download a PCM wiring diagram. You have to tap into your #46 wire and run a switch from the wire with a ground....Or has anyone done this before........Thanks...............
