05-18-2009
#10 |
| | Re: ok got 2 problems well i went w/ the mm cc kit and the ford racing intake,as for the strutt thing when you lower a car with out changing struts to shorter strutts you run the problem of possible bottoming out the strutts bcuz to get decent suspention travel you sould remove the bump stops hence creating the problem,i thought about going with shorter strutts but if i blew one one the road chances of finding a replacement is a lil iffy,so i went w/ the max motorsports,i was debating between them and the steeda set,dollar vs dollar mm won ,mann the car handles nice when you have a tight front end
__________________ 2003 gt redfire ,eibach lowering kit,cobra r rims,coi,plus some other lil things |
