THe odometer IS the PAT, I swapped mine out and and all I had to do is change the digital odometer, you have to take the cluster apart to get to it, you can use your circuit board also. mine had a bad tach, I got one from an 03 and tried it but wouldn't start, once I swapped the odometer it fired right up
