count the number of teeth on the ring gear and the pinion gear. Divide the number of ring gear teeth by the number of pinion gear teeth. The resulting number is your gear ratio. (For example, a ring gear with 39 teeth and a pinion gear with 11 teeth: 39 divided by 11 is 3.5454...; these are 3.55 gears)
