you might try asking about the certificate here
http://www.mach1registry.com/index1.htm
apparently they are not serialized
7. Will they be serialized?
NO, but the Mach 1's will have an old distinctive 'R' Engine Code in the VIN #, this is unique to the Mach 1's only.
i.e.) 1FAFP42R43F371400
The LAST 6 Digits is the Sequence number of all Mustangs (V6's, GT, etc.). The 2003 Model year starts at 300001, therefore, if your VIN # is 371400, your mustang is approx. the 71,400 off the assembly line.
Once 2003 Production is complete, we will hopefully get a complete Mach 1 VIN list and then we can tell you where you fall in the production #'s.
[FONT=Verdana, Arial, Helvetica, sans-serif]
Typical VIN [/FONT]
Position Number [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 1-3 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
World Manufacturer Identifier[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 4 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Restraint System Type
Brake Type and GVWR Class
(Trucks and Vans Only)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 5-7 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Line, Series, Body Type[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 8 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Engine Type[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 9 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Check Digit (Random)[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 10 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Model Year[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 11 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Assembly Plant[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Position 12-17 [/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]
Production Sequence Number[/FONT]
