I have a stock 1999 front end that doesn't have the fog lamps, It never had them. I looked behind the bottom fender and it looks like it has the mounts where the fog lamp brackets would bolt or screw on.
My question is, can I cut flush the bottom inlets and bolt on the Mustang fog lamps? Or would it be better to change the front end all together that was made for them?
I don't have a fog light switch or relay for the fuse box. Would it be a pain to add the switch? Or should I just run them off my running lights electrical system? I never modified lights before and would like some advice. Thanks
