View Poll Results: Vote now for July MOTM
StrongStang50 39 26.17%
RustyNutz 38 25.50%
Jared88 36 24.16%
Irishpwr46 36 24.16%
Voters: 149. You may not vote on this poll
Old 07-20-2009   #1
Founder / Admin
MineralGray02K's Avatar
Liked: 1504 times
NYM Trader: 8
MineralGray02K's Pictures MineralGray02K's Garage
MineralGray02K's latest status update: Stone Temple Pilots kick out Scott Weiland!?­! http://­flark.it/­ay8
Default July 2009
Congratulations StrongStang50 for winning July MOTM!
From StrongStang50:
I purchased this car when I was 16 years old (10 years ago). It was the car of my dreams! I worked all through high school sometimes 2 and 3 jobs to pay for the car, the MODS, the tickets I received in the car and the insurance on my own. It’s been an ongoing project since I bought it. The day I bought the car it was nicknamed “The Strong Stang” by a co-worker at the time and the name stuck over the years.
What makes this car so special to me is I have turned every bolt and physically built this car from the ground up on my own. I have been with it through thick and thin including lying on concrete floors all winter to get it done and ready for spring. Even staying up to 3am when I had to work in a couple hours!! The part that makes it all worth it is when you are on the highway and you pull up to a car with kids in it and they all glue themselves to the window and you can see them saying WOW, Mom and Dad check that car out!!! There’s nothing on the face of the planet that is better than an excited kid!
Interior:
8 point roll cage with door hinges hand painted with POR 15
Corbeau racing seats
Corbeau 4 point seat belts
Triple gauge pod displaying all Autometer gauges
5" monster Autometer tach.
UPR petals with 5.0 logo
UPR knobs and other interior accessories
FRPP floor mats
Exterior:
Cobra headlights
Clear side marker lights with red bulbs
98 style tail lights with wiring harnesses
Diamond cut fog lights
3 1/2" cobra RR SVO hood by Cervinis
5.0 fender badges
The windshield has been tinted on the top
UPR chrome windshield wiper delete kit
UPR shorty antenna
DEI Viper alarm system
Weld 3 ½” x 15’s up front and Weld 10 x 15’s out back with BFG Drag T/A’s
Rear chrome bumper inserts from American Muscle
Suspension and Brakes:
UPR upper control arms
Lakewood traction bars
KYB AGX 8 position adjustable gas shocks
KYB AGX 4 position adjustable gas struts
Energy suspension master polyurethane bushing kit
UPR 4 way adjustable caster camber plates
Eibach drop kit
Energy Suspension Poly Engine mounts
Energy suspension Poly Transmission mount
Energy suspension sway bar end link kit
FRPP Ball joints
FRPP inner tie rod ends
FRPP outer tie rod ends
Brembo drilled slotted rotors
Hand painted red calipers
Hurst Line-lock (waiting in my garage to be installed)
Drivetrain:
4.10 gears
AODE transmission (built by Ken Jewett at Jewett’s transmissions)
B&M shift kit
B&M shifter
B&M deep pan with temp sensor
2800 stall converter (soon to be changed)
FRPP aluminum drive shaft
Lakewood drive shaft safety loop
FRPP rear end girdle
Engine:
302 .30 over (306) 9.5 / 1 CR
AFR 165 Heads CNC ported by Camshaft Innovations with valve spring upgrade
Custom ground cam by Camshaft Innovations
ARP head studs
Crane 1.7 roller rockers
Crane Roller Lifters
Custom pushrods by Steve Stack at XLR8 Motorsports
Canton 7 qt oil pan
Main girdle with ARP main bolts
Windage tray
ARP oil pan bolts
JLT CAI Torch Red
MAF with 30# tune and cold air tune
Edelbrock 70mm throttle body powder coated black and hand painted red raised letters
Edelbrock elbow powder coated black and hand painted red raised letters
Edelbrock performer II upper intake powder coated black and hand painted red raised letters
Trick flow 1" intake spacer
Edelbrock performer II lower intake powder coated black and hand painted red raised letters
Cooling:
Fluidyne radiator with built in transmission cooler
FRPP high flow water pump
Mr. Gasket 180 Degree thermostat
FRPP water outlet powder coated black
External transmission cooler with thermostat and built in fan with custom made brackets
Ignition system:
Red top optima dry call battery
MSD 6AL
Pro bullit MSD distributer with hardened shaft
MSD cap and rotor
MSD 9mm wires
Taylor trunk mount battery kit (waiting to be installed)
Fuel:
255lph BBK fuel pump
Aeromotive fuel pressure regulator
FRPP 30# fuel injectors
Fuel pressure gauge
Exhaust:
MAC ceramic coated long tube headers
Stage 8 locking header bolts
MAC ceramic coated pro-chamber
SLP loudmouth cat back
I also have to add the car was tuned by Mustang Magic!
Original Post
Nominations are in and it looks like it's going to be another tough decision! Vote away people
StrongStang50
RustyNutz
Jared88
Irishpwr46
NYM Mobile
NYM Badge
MineralGray02K is online now
Old 07-20-2009   #2
Clubhouse Moderator
1990_LX's Avatar
Liked: 274 times
NYM Trader: 3
1990_LX's Garage
Default Re: Vote now for July MOTM!
AHH! It's so tough but my vote goes for Rob, that thing is bad ass! Good luck everyone!
-1989 LX 5.0 - 5 speed, OBX long tubes, VRS SS X pipe, MAC catback, Eibach springs, SVE upper/lower control arms a bunch of polyurethane stuff, KYB shocks/struts, Edelbrock Performer intake, Holley 600
-1995 3.8 - True duals(divorced), Flowmaster 40s, Hurst short throw, CAI, EGR/DPFE Delete, 215k + mi(DD)
1990_LX is offline
Old 07-20-2009   #3
Central NY & Cobra Moderator / Member Plus
Timspony's Avatar
Liked: 1158 times
NYM Trader: 15
Timspony's Pictures
Timspony's latest status update: Tomorrow's CRUISE in the Albany area has been Postponed !!!! :( ...
...this should be a good race!
2003 SVT Cobra Mustang Coupe...Just a 10 sec. POSI Eaton
2004 SVT Cobra Mustang RagTop
Timspony is online now
Old 07-20-2009   #4
94Gt5.0's Avatar
Liked: 5 times
94Gt5.0's latest status update: fanfuckintastic
Gotta give a little SN95 love to Rob!!
Run what ya brung, we brought more!
94Gt5.0 is offline
Old 07-20-2009   #5
Resident Badass
OhTreShinyGrey's Avatar
Liked: 2 times
NYM Trader: 2
OhTreShinyGrey's Pictures OhTreShinyGrey's Garage
OhTreShinyGrey's latest status update: looking for some help.
oh and Rob takes the lead!
2003 Dark Shadow Grey GT
OhTreShinyGrey is offline
Old 07-20-2009   #6
Jenzpony's Avatar
Liked: 466 times
NYM Trader: 2
Jenzpony's Pictures Jenzpony's Garage
Jenzpony's latest status update: with our eyes wide open, we rise and fall.
how can u even compare these cars? Honestly i think the MOTM should be changed around to categorys or sections.. these cars are all powerful special and unique in their own way so how can you compare a cobra to a mint condition sn95 to a unique body kit s197 and so on...CONFUSION!
-1998 Mustang GT Coupe- CAI, BBK O/R X, SLP LMII, Pro 5.0, B-springs w/ KYB's, 17x9 Cobras w/ BFG G-Force Sports,
-1991 Mustang GT Hatch- The Original Jenzpony K&N, Flowmaster 40 catback *Sold*
Jenzpony is online now
Old 07-20-2009   #7
Resident Badass
Liked: 2 times
NYM Trader: 2
And rob's horses pull away!
Old 07-20-2009   #8
BKD
BKD's Avatar
Liked: 243 times
BKD's Pictures BKD's Garage
BKD's latest status update: just hit $50 on a $2 scratch off ticket..............wooo hooo ...lol .
this is hard to do or something.........
names ...BRIAN.
my DD
BKD is offline
Old 07-20-2009   #9
BOSS10L's Avatar
BOSS10L's Pictures
BOSS10L's latest status update: embarking on an epic journey.
Rank: 1
Quote:
I have to agree with Jen on this one. They're all very fine specimens, but it's like comparing apples to oranges. Yeah, they're both fruit, but are unique and different in their own ways...Maybe that didn't come out the way I wanted it to, but I hope you guys/gals get my point.
While I like the idea of having a MOTM, at the end of the day it ends up being either a popularity contest, or a divisive line between who likes what styles of Mustangs.
I voted for Rusty, that is one sexxay black snake. Granted, StrongStang's my hombre on this board, but in all honesty, the only SN-95s I like are the '96 Mystic Cobras and the '98 Chrome Yellow / Bright Atlantic Blue Cobras. That's not a knock against his Pony, it's [Night at the Roxbury] sweet ass sweet [/Night at the Roxbury], but just not my style.
'91 Mustang LX 5.0 AOD - Project Felonious Filly
'88 GT T5 - Sold (the one that got away)
'87 GT T5 - Sold
'01 V6 AODE - Sold
BOSS10L is offline
Old 07-20-2009   #10
04 orange cobra's Avatar
Liked: 237 times
04 orange cobra's Pictures 04 orange cobra's Garage
04 orange cobra's latest status update: Is this WEATHER ever going to break !!!!
SORRY...Rob nice car for sure ....But have COBRA IN MY BLOOD...That is one BAD ... WHIPPLED ....COBRA
04 orange cobra is online now
Old 07-20-2009   #11
Timspony's Avatar
Liked: 1158 times
NYM Trader: 15
Timspony's Pictures
...Gotta remember, whem MOTM was started, we only had a limited amount of members....NYM has GROWN very quickly & maybe it's time to change things up!
...So, maybe in the near future, MOTM should be broken in groups such a Fox's, SN-95's, Termi's, S-197's, Classic's...to play on equal ground! Just my
Old 07-20-2009   #12
Wicked One's Avatar
Liked: 751 times
NYM Trader: 3
I was thinking, have the previous months winner select 3 of his/her own choices for the next month.
Make sure to check out the NYM STORE.
Officer, I know I was going faster than 55MPH, but I wasn't going to be on the
road an hour. -- Steven Wright
Wicked One is offline
Old 07-20-2009   #13
1BIGMOFO's Avatar
Liked: 705 times
NYM Trader: 9
1BIGMOFO's Pictures
1BIGMOFO's latest status update: It's a great feeling when being a winner is part of your DNA!
^^ I agree with you Greg. In all honesty im honored to be up there with these 3 other beautiful cars.
1BIGMOFO is offline
Old 07-20-2009   #14
Timspony's Avatar
Liked: 1158 times
NYM Trader: 15
Timspony's Pictures
Quote:
...that could turn into a regional game!
Old 07-20-2009   #15
Wicked One's Avatar
Liked: 751 times
NYM Trader: 3
There would be rules applied obviously. Not sure yet, we will see.
Time for July MOTM Voting! NYstang 2009-2010 Winners 79 06-30-2010 10:19 PM
Time for July MOTM Nominations! NYstang 2009-2010 Winners 68 06-13-2010 08:32 PM
July 11 & 12 bruiser937 Upcoming Events 7 07-11-2009 11:33 PM
4th of July 2007VistaBlueGT Long Island 12 07-06-2009 09:50 AM
New England Summer Nationals [July 2 - July 5, 2009] MineralGray02K Upcoming Events 7 02-03-2009 07:06 AM
