New York Mustangs - Forums » Classifieds » Mustang Parts » Drivetrain Parts » JE Pistons 257947 - JE Pistons Big Block Inverted Dome Top Pistons $150
Old 10-06-2009   #1
Leave Trader Feedback
Default JE Pistons 257947 - JE Pistons Big Block Inverted Dome Top Pistons $150
I got nine for sale.
I have 9 (NINE) of these exact pistons for sale. Throw me your offers *EDIT* Who ever could offer more then $150 first gets them. *EDIT
I just want to get rid of stuff in my house not being used. Moving soon, don't want extra baggage.
I am located in Yonkers, New York. ALL BRAND NEW STILL WRAPPED UP. Please take them off my hands.
My email address is faridhakimxx129@gmail.com
I will only do meet ups, no shipping.
http://www.summitracing.com/parts/JEP-257947
JE Pistons big block inverted dome top pistons are compatible with forced induction, nitrous and angle milled heads. The inverted dome shape has been designed for maximum efficiency and horsepower, and the valve reliefs will accommodate oversized valves and long duration, tight lobe separation cams. Compression height is figured using 9.780 block height with zero deck clearance, and the precision CNC machined ring grooves accept 1/16, 1/16, 3/16 rings. These pistons will fit both open and closed chamber cylinder heads
Brand JE Pistons
Manufacturer's Part Number 257947
Part Type Pistons
Product Line JE Pistons Big Block Inverted Dome Top Pistons
Summit Racing Part Number JEP-257947
Bore (in) 4.500 in.
Bore (mm) 114.300mm
Piston Style Dish, with single valve relief
Piston Material Forged aluminum
Compression Distance (in) 1.395 in.
Piston Head Volume (cc) +28.00cc
Wrist Pin Style Press-fit or floating
Pin Diameter (in) 0.990 in.
Piston Ring Thickness 1/16 in. x 1/16 in. x 3/16 in.
fariidx is offline   Reply With Quote
9 JE Pistons Big Block Inverted Dome Top Pistons $400 fariidx Modular Motor Parts (96 - 14) 1 10-25-2009 05:19 AM
JE Pistons 257947 - JE Pistons Big Block Inverted Dome Top Pistons fariidx Windsor Motor Parts (5.0 / 5.8L engine parts) 0 10-06-2009 05:14 PM
2008 bullitts have stronger pistons. navyman8903 2005 - 2010 3 06-12-2009 05:22 PM
F/S: Probe Forged SRS flattop pistons for 347 EvinH Windsor Motor Parts (5.0 / 5.8L engine parts) 0 02-28-2009 10:53 AM
