[FONT=Arial, Helvetica, sans-serif]How To Install Bullitt Pedals[/FONT]
[/FONT]
The stock gas pedal on my '00 Mustang was about 1" lower than the brake pedal, making it almost impossible to heel & toe on a downshift. I did the Mustangworld pedal raising fix but there still remained about 3/8" difference in height between the pedals. Grrrr.
Ford raised the gas pedal on the "Bullitt" Mustang, so I purchased a Bullitt pedal set. It raises the stock pedal about 1/2" - not enough. But if you then add the Mustangworld fix, it comes out just right. I now have accelerator and brake pedals at exactly the same height.
[/FONT]
[FONT=Arial, Helvetica, sans-serif]The stock gas pedal on my '00 Mustang was about 1" lower than the brake pedal, making it almost impossible to heel & toe on a downshift. I did the Mustangworld pedal raising fix but there still remained about 3/8" difference in height between the pedals. Grrrr.
[/FONT]
INSTALLATION
[/FONT] [FONT=Arial, Helvetica, sans-serif]
[/FONT]
- [FONT=Arial, Helvetica, sans-serif]The dead pedal plugs into a plate attached to the left kick panel. Just pry off the old pedal and plug in the new one.
[/FONT] - [FONT=Arial, Helvetica, sans-serif]Remove the two 13mm nuts than hold on the stock gas pedal. Slip the plastic grommet out of the top of the pedal assembly to free the cable.
[/FONT] - [FONT=Arial, Helvetica, sans-serif]Install the Bullitt pedal assembly, reinstall the cable & grommet, reinstall the Mustangworld spacer if you had one.
[/FONT] - [FONT=Arial, Helvetica, sans-serif]Before installing the clutch & brake pedal pads, smear the backs with liquid soap. It's just about impossible to get them on if you don't use some kind of lubricant. [/FONT]
Ford stock numbers (Ford dealer parts department)
[/FONT]
- [FONT=Arial, Helvetica, sans-serif]1R3Z-9725-AA (SHAFT ASY ACCE) - accelerator pedal assembly
[/FONT] - [FONT=Arial, Helvetica, sans-serif]1R3Z-2457-AA (PAD-BRAKE PEDA) - brake & clutch pads
[/FONT] - [FONT=Arial, Helvetica, sans-serif]1R3Z-6312024-AA (FT/RST AST-DRV) - foot rest
[/FONT]
- [FONT=Arial, Helvetica, sans-serif]FMS-M-2301-A - gas pedal cover [/FONT]
- [FONT=Arial, Helvetica, sans-serif]FMS-M-2301-B - brake or clutch pedal cover [/FONT]
- [FONT=Arial, Helvetica, sans-serif]FMS-M-2301-C - left foot dead pedal cover [/FONT]
[FONT=Arial, Helvetica, sans-serif]found @ 2000 Mustang V6 5spd Convertible[/FONT]
