The battery died, again, nothing new there.
I did a little lighting effects in my car this week.
Added led ambient lights, and removed the courtesy lamps and replaced them with led's, not led lamps, but through hole led's.
After all done, I fire up the car and I have a few problems.
Things I checked
Thanks guys, I am at a loss here. The car runs fine, just those above problems. Do not know if the speedo works, did not go anywhere.
And I am not going to the previous dealer I was at. Gonna go to Scarsedale Ford. Let them figure the shit out, I am getting tired of this crap.:smash::smash::smash::smash:
- The tack doesn't work
- 90% of the dash icons are lit up in the gauges (traction control, wrench, airbag, brake, check engine)
- the tcs switch in the center will not turn off, it is always illuminated.
- convertible top button does not work
- the data display says,"check charging system, check brake system"
- when I turn the key on, the tach and speedometer needle go down but return to zero.
Things I checked
- Every fuse in the entire car
- tried to read any codes with my x3, but said "error getting code count"
- tried to read my strategy, "error reading strategy"
- checked all connections.
- Removed all prior installation
