Ford Racing Bellhousing Tremec TKO500/TKO600/3550 289/302/351 1982-1995Ford Racing Bellhousing for 1982, 1983, 1984, 1985, 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 and 1995 Mustangs with a 289, 302 or 351W Engine and Tremec TKO500, TKO600 or 3550 Transmission.
If your transmission in your 1982-1995 Mustang is damaged and you decide to upgrade to Tremec TKO500, TKO600 or a 3550 this bellhousing is a must. Due to the Tremec transmission having a unique bolt pattern, Ford Racing makes this possible to mount a Tremec transmission to a 289, 302 and 351W engine
The Ford Racing Tremec bellhousing will only work with a 157 tooth flywheel. Tremec bellhousing will also fit 1965, 1966, 1967, 1968, 1969, 1970, 1971, 1972 and 1973 Mustangs with a Tremec TKO style transmission
