New York Mustangs - Forums » Mustang Specific Tech » 5.0 Mustangs » What Does the HO stand for in 302 5.0 HO engines
Old 10-09-2009   #1
Jthavok21's Avatar
Jthavok21's Pictures Jthavok21's Garage
Jthavok21's latest status update: Frustrated
Default What Does the HO stand for in 302 5.0 HO engines
Just wondering because i need to know the distributor firing order on my car and need to know if it's an ho engine or not
Jthavok21 is offline   Reply With Quote
Old 10-09-2009   #2
toomanytoys's Avatar
toomanytoys's Pictures
Default Re: What Does the HO stand for in 302 5.0 HO engines
The HO means high output
1988 LX-331ci,TFS heads,gt40 int,55lb inj,s-trim,e-303,msd 6al,a/c delete,smog delete,centerforce clutch,tremec 3550,alum ds,tru-trac, 3.73s,c-clip elim,southside lowers
03 Zinc Yellow Cobra-Pullied,JLT intake, Pypes exhaust,Bama tune,18" black Bullits
2007 Hayabusa-2 Brothers m2 vale exhaust,K&N,frame sliders,blue leds,iridium windscreen,xenon headlights,pcIII
toomanytoys is offline   Reply With Quote
Old 10-09-2009   #3
aloha moloi`eheme
lonepalm's Avatar
Liked: 24 times
NYM Trader: 1
lonepalm's Pictures lonepalm's Garage
High Output
Paul
lonepalm is offline   Reply With Quote
Old 10-09-2009   #4
GT40Mustang's Avatar
GT40Mustang's Garage
GT40Mustang's latest status update: ....
High output As for the firing order it's 1-3-7-2-6-5-4-8
GT40Mustang is offline   Reply With Quote
Old 10-09-2009   #5
Or a VERY loose woman !!
Old 10-09-2009   #6
363Coupe's Avatar
363Coupe's Pictures 363Coupe's Garage
Huge Ostrage
_____________________________________________________________________________
___________________________TURBOPEOPLE / SUPERSTREET / KOGAN MOTORSPORTS / WOLFE RACECRAFT_________________________
IF YOU WANT CHEAP IT WONT BE FAST, IF YOU WANT FAST IT WONT BE CHEAP, AND IF YOU WANT FAST AND CHEAP IT WONT BE GOOD.
363Coupe is offline   Reply With Quote
Old 10-09-2009   #7
Vanstrom Performance
EHA Racing's Avatar
Liked: 161 times
NYM Trader: 4
EHA Racing's Pictures
EHA Racing's latest status update: ridin' on a dolphin, doin' flips and shit....
A small block Ford has 2 firing orders depending on the cam that is in them. Remember it's not a Chevy LOL so cylinders 1 - 4 are on the passenger side and 5 - 8 are on the drivers side.
The HO firing ordrer is 13726546
Depending on the cam that it has it could be 15426378
EHA Racing is offline   Reply With Quote
Old 10-09-2009   #8
Jthavok21's Avatar
Wow i'm retarded, i should have known that
my firing order doesn't match the firing order for a regular 302 so maybe it it a H.O.
Also the 8th cylinder is on the front left when looking at the front of the car is that normal, and the 1st cyl. is in the back right.
Old 10-09-2009   #9
aloha moloi`eheme
lonepalm's Avatar
Liked: 24 times
NYM Trader: 1
Why does 6 fire twice but 8 never fires? lol
Paul
Old 10-09-2009   #10
Jthavok21's Avatar
lmao Good one
Old 10-09-2009   #11
EHA Racing's Avatar
Liked: 161 times
NYM Trader: 4
No, #1 is left front when looking at the engine from the front. #8 is right rear back by the brake booster.
Standard
5.0 HO
Quote:
OOPS. My sausage links got in the way LOL
13726548
Old 10-09-2009   #12
Mmmmmmm- sausage................
Old 10-09-2009   #13
jkstang78's Avatar
Liked: 20 times
NYM Trader: 2
jkstang78's Pictures
jkstang78's latest status update: Diana What are you RAWRING About
H.O. Stands for HOLD ON.
MM&FF Hooligan Hot Rod http://www.cardomain.com/id/jkstang78
"Real cars don't power the front wheels, they lift them"
best 9.39 @ 143
jkstang78 is offline   Reply With Quote
Old 10-09-2009   #14
Jthavok21's Avatar
ok well i know i have a 302 but my firing order on the distributor doesn't match either of those, i've checked them over and over again, so i don't know what the hell they did to the engine before i had it, i think i heard from the guy i bought it from that it was camed, but i have no way to know because there is no cam pully unless it's in the enigine and runs off the crank itself. so i'm kinda screwed unless one of you live around me and can come help me out.
Old 10-09-2009   #15
NickT02LS's Avatar
NYM Trader: 1
NickT02LS's Garage
NickT02LS's latest status update: exhausted
Not sure what you are doing to determine the firing order, but if you are looking at numbering on the wires someone could have used lets say a number 8 on the wire going to cyl. 4 and it could screw you up. Also make sure you are using the correct distributor rotation when checking the firing order. Follow each wire from the cap all the way to the plug so you know which cylinder it is actually going to.
NickT02LS is offline   Reply With Quote
Search this Thread:
Advanced Search
55 Gallon fish tank and stand Mr. Sonic GT. Miscellaneous 10 03-12-2011 03:51 PM
1/4 Mile Wheel Stand and Them Some!!! SSChris NY. Clubhouse 9 09-19-2010 03:54 PM
engines out! cobrastang161 Misc. Pictures 9 06-20-2009 10:52 PM
Ford Modular Engines F.A.Q RideThePony2004 1996 - 2004 4 04-21-2009 10:11 PM
buffalo,ny stand up!!!!!!!! MOE New Member Introductions 78 01-25-2009 02:29 AM
