New York Mustangs - Forums » Non-specific Tech » Show Time » cleaning engine bay??
Like Tree3Likes
  • 3 Post By Wicked One
Old 12-17-2011   #1
Broome County Coordinator
kelpen's Avatar
Liked: 158 times
NYM Trader: 1
kelpen's Pictures kelpen's Garage
kelpen's latest status update: Binhamton Cars and Coffee Sept. 13th .. http://­www.newyorkmustangs.c...
Question cleaning engine bay??
looking for the best way to clean and maintain the engine bay
kelpen is offline   Reply With Quote
Old 12-17-2011   #2
Wicked One's Avatar
Liked: 824 times
NYM Trader: 3
Default Re: cleaning engine bay??
Here you go.
This is what I do as do a few members here also.
Start engine, get it warm, not hot, just nice and warm. As an example if the car was fully cooled, run it for 5-8 minutes. Turn off engine.
Cover the alternator and air filter on your intake, Aluminum foil works great since the motor is warm. Everything else can be subject to light rinsing type spray, including the covered fuse panel. All of these areas get hit by water when driven in the rain.
Lightly spray entire engine bay with water from hose, you will see some light steaming, this is good.
Spray the entire engine bay, including firewall, plastic parts, metal parts, loom, coils and hoses with Simple Green. Set the hood down, not fully closed, just to it's safety catch point, and go find something else to do for 15 to 20 minutes. Let the simple green do it's work. Closing the hood let's the simple green interact with the steam you created with the warm motor. This loosens the tough stuff up so you don't have to work so hard in those heavily soiled areas.
Open hood, look for heavily soiled areas, wipe them with a rag, use more simple green if necessary. Rinse lightly with hose.
Spray entire engine bay with F-21, it foams, coat everything just like the simple green coating you did.
Close hood again, walk away for 10-20 minutes or until nearly all the foam has dissipated.
Open hood, Wipe up any areas that water settled and such. Wipe up any areas that the F-21 didn't dissipate on it's own.
You will note that the F-21 restores the black plastic parts to the same oem flat black color they were when new.. It leaves the paint shiney with no streaks on the fenders and fire wall. Best of all, it is not greasy to the touch.
Grkstang, AlloyGT07 and kelpen like this.
Make sure to check out the NYM STORE.
Advertise On NYM!! details here
Wicked One is offline   Reply With Quote
Old 12-17-2011   #3
AlloyGT07's Avatar
Liked: 143 times
AlloyGT07's Pictures AlloyGT07's Garage
I usually turn on the engine for a few minutes so its nice and warm, cover the CAI filter and spray on Gunk Engine Degreaser. Let that sit for about 10-15 minutes and then rinse everything with water. Use a piece of cloth to dry everything off and remove extra dirt that hasn't been removed.
Just as a side note, the engine degreaser smells pretty bad and stinks up the inside of the car. its important to leave the hood and windows open. If you plan on driving right after, you'll have to deal with the smell for some time. :/
2007 Alloy Clearcoat Metallic
AlloyGT07 is offline   Reply With Quote
Old 12-17-2011   #4
On Edge's Avatar
Liked: 1019 times
NYM Trader: 8
On Edge's latest status update: Happy New Year everyone !! It's going to be a great year !!
Quote:
Originally Posted by Wicked Xtreme View Post
Here you go.
greg, hope all is well.
what is f-21, and is it a specialty item or can i purchase it at pep boys or the local auto store ?? thanks.
On Edge is offline   Reply With Quote
Old 12-17-2011   #5
kelpen's Avatar
Liked: 158 times
NYM Trader: 1
Thanks for the help. I'v never been a fan of water under the hood. but I guess I just need to grow a pair...lol
Thanks again
Old 12-17-2011   #6
BAzombie's Avatar
Liked: 127 times
BAzombie's Pictures BAzombie's Garage
BAzombie's latest status update: In search for a set of 4.10's for an 8.8 that's going into my Jeep. Will buy or trade...
F21 can be pickled up at any auto parts store.
R.I.P my love
BAzombie is offline   Reply With Quote
Engine cleaning bigredshaolin Clubhouse 6 03-22-2011 07:17 PM
The best method for cleaning engine bay Wicked One Show Time 2 08-01-2009 02:17 PM
Cleaning up joboo Wheels & Tires 14 05-23-2009 09:39 AM
Cleaning engine Wicked One Show Time 2 05-07-2009 08:27 PM
Ford's Romeo Engine Plant Builds 10 Millionth Engine MineralGray02K Mustang News / Site News & Updates 0 02-19-2009 01:40 AM
