New York Mustangs - Forums » Mustang Specific Tech » Modular Mustangs » SVT Cobra & 03 / 04 Mach 1 » What can I fit over Wilwood 6 Piston & 4 Piston Calipers
Old 01-18-2010   #1
Rob_03Cobra's Avatar
Liked: 9 times
Rob_03Cobra's Pictures Rob_03Cobra's Garage
Default What can I fit over Wilwood 6 Piston & 4 Piston Calipers
I'm looking to pick up some Street/Strip 16" Slicks but I guess that aint happening.
Anyone with a Cobra running 6 piston Front and 4 piston Rear Wilwoods know what Rim Tire Combo can be used ???
Thanks
03 Cobra, Built Motor, KB 2.8H, PA 4r70w, PI 3500 Triple Disc Lockup Conv
PI Manual Valve Body, Transbrake, 8.8 SRA Rear, 3.73 Gears, Eaton Posi,
Moser 31 Spline Axles, AND A LOT MORE... Details Here -- Fun Vid Here
SOLD MAY 12th 2011
Rob_03Cobra is offline   Reply With Quote
Old 01-18-2010   #2
NYC Regional Coordinator
MaximumRisk's Avatar
Liked: 260 times
NYM Trader: 6
MaximumRisk's Pictures
MaximumRisk's latest status update: I wish I could be poor for just one day......because this crap of being poor everyday is...
Default Re: What can I fit over Wilwood 6 Piston & 4 Piston Calipers
The only drag wheels THAT I KNOW OF that will clear big brakes is the newer version of the CCW's drag pack. I have seen them on newer Shelbys with the 14" rotors and brembo calipers and they told me that they would clear my Alcon calipers with 14" rotors
when I spoke to them a little while back.
Give them a call, see what they tell you.
MaximumRisk is online now   Reply With Quote
Old 01-18-2010   #3
Liked: 9 times
After 9 years and 3 Gen II Lightnings I had so many dam rims and tires I couldnt fit them all. I sold the L recently with (4) 18" Chrome OEM Rims with Nitto 555's all around, (4) 15" Bogart D-10 with Hoosiers all around, (Fatty's & Skinnys), (2) 15x10 Chrome Custom Made 1 off Rear Rims, (2) 16" Steel Rims with Hankooks, and (2) 15" x 12" Prostars w/30x13.5 ET Street DR's.
Now I have to start all over they were all 5x135 except the Prostars that were 5x4.5
I was hoping I could just grab a set of 15" Prostars or maybe some 16" rears rims w/ ET DR's but I guess with the Big Brakes that aint happening hu ? I know the CCW's are expensive maybe I'll just get an extra set of 18" rims like I have now and throw some slicks on them. I can get dam near new Hoosier 275 X 35 X 18 Slicks for $80.00 each on e bay but there a little too short (25.58), I rather go taller than I have now (26.41).
I currently have BRAND NEW 305/35/18 Nitto DR's but we all know they're basically useless , maybe I'll try some taller ET Street Radial II's ???
Thanks
If anyone knows / has a Big HP Big Brake Cobra please let me know what Tire/Wheel Combo you know of for Racing/Street Fun
SOLD MAY 12th 2011
Old 01-18-2010   #4
Central NY & Cobra Moderator / Member Plus
Timspony's Avatar
Liked: 1156 times
NYM Trader: 15
Timspony's Pictures
Timspony's latest status update: Great day for the Opening Day at the Harbor House!!!! .... Hope to see you there! :)
...any tire on the streets right now are useless!!! ...wait to the streets get warmed up come spring!
2003 SVT Cobra Mustang Coupe...Just a 10 sec. POSI Eaton
2004 SVT Cobra Mustang RagTop
Timspony is online now   Reply With Quote
Old 01-18-2010   #5
Liked: 260 times
NYM Trader: 6
what size rotors are you running in the rear?
I had 13" rotors, but went back to stock setup so that I was able to fit 16" wheels back there for a little more sidewall/ better choice of tires
You might not want to do that, but it is an option
Old 01-18-2010   #6
Liked: 260 times
NYM Trader: 6
or you can always get BFGoodrich G-force t/a drag radials in 18" (315-30)
Old 01-18-2010   #7
97modgt's Avatar
Liked: 21 times
97modgt's Pictures
97modgt's latest status update: Goodmorning New York Mustangs
I concidered this cause i have a set of welds with ET streets that I can't use and the nitto's I have now don't hook up.
97modgt is offline   Reply With Quote
Old 01-18-2010   #8
Liked: 9 times
Great Feedback in info THANKS
Quote:
Ya tell me about it, I go through this every winter
Def a thought I guess, Thanks...
Excellent tire and traction but I've had friends burn a set up in one day on the 1320, I have NEVER scene anything wear like they do
(but they do have some GREAT traction )
Quote:
I tried Nitto's on all 3 Lightnings and never found them even decent
(of course your power level plays a big part)
I may just pick up an extra set of rear rims and throw some ET Street DR II's or full slicks on them and see how that goes
SOLD MAY 12th 2011
Old 01-18-2010   #9
Liked: 260 times
NYM Trader: 6
just remember that you cannot mix radials with bias. It is not safe!
Old 01-19-2010   #10
Glueyes's Avatar
Liked: 174 times
NYM Trader: 2
Glueyes's latest status update: when in doubt,whip it out!!!!!
I run a ccw drag pack 17's upfront and 16's in the back.Honestly that size wheel in order to clear big brakes will have to be custom..The ccw drag pack is not that steep..It ran me 2500 shipped to my door with tires and lug nuts.Good luck
Glueyes is offline   Reply With Quote
Old 01-20-2010   #11
Liked: 9 times
Do you think 345/30-18 would fit ???
(I have 305/35-18 now)
SOLD MAY 12th 2011
Old 01-20-2010   #12
Liked: 260 times
NYM Trader: 6
I know Joe (from Mustang Magic) had a set on Snakebite so you can make them fit. What did he do to make them fit? that I do not know, but you can call him and ask.
Old 01-20-2010   #13
Liked: 9 times
I really have to Thank Everyone for the advise and suggestions
I just sold (6) 15" Rims/Tires, (4) 18" Rims/Tires, and (2) 16" Rims/Tires that all fit my 00 Lightning (the new owner took everything).
I had it all figured out and now I have to start my wheel collection all over
Those CCW's are expensive as hell compared to Prostars or other aftermarket but I guess they may be one of the only choices if I want to go smaller + taller, If someone ever gets a chance to post a pic or give me a Mod# and BS I'll have to keep my eyes open for something used (even just two for the back).
I just dont want to make the same mistake I made with the L and end up with (12) Rims and Tires, and have to switch 4 around every time I want traction on the street. Knowing what I know now (thanks to you guys) I think I'll most likely look for an extra rear set of Saleen Rep Rims 's like I have now (18x10's) and then try running REAL 18" DR's (not useless Nitto's).
I would love to know if I can fit these 345/30-R18's
(I do have a 1" spacer on the rear with the 18x10's 6.5 BS, in theory I think they woudl fit ???)
(you can get a used set cheap enough)
THANKS AGAIN
SOLD MAY 12th 2011
Old 02-14-2010   #14
Liked: 1 times
you will probably need to roll the fenders. mine rub and i think i have 315's
halflife is offline   Reply With Quote
Search this Thread:
Advanced Search
Wanted brembo 4 piston calipers sn95 Slowpoke Want To Buy (WTB) 0 10-11-2009 05:57 PM
Piston Problems.. SubZero00GT SVT Cobra & 03 / 04 Mach 1 15 07-03-2009 05:58 PM
Will these calipers fit on my stang? OhTreShinyGrey 1996 - 2004 8 06-29-2009 02:31 AM
How to Paint your Brake Calipers MustangCars.info Write Up's, How To's, Installation / Uprgrade Info 0 01-20-2009 07:38 PM
