New York Mustangs - Forums » Mustang Specific Tech » Modular Mustangs » 2005 - 2010 » Brembo brakes hubcentric spacers??
Like Tree3Likes
  • 2 Post By On Edge
  • 1 Post By Matt@RealSpeed
Old 03-25-2015   #1
05GTNYYNYG's Avatar
05GTNYYNYG's Pictures 05GTNYYNYG's Garage
05GTNYYNYG's latest status update: i wish i could close my eyes for 24hrs
Default Brembo brakes hubcentric spacers??
So I recently picked up a set of Gt500 front brakes(Brembo) that were a take off from a friend of mine but the calipers do not fit inside the wheel (20x8.5 american racing torque thrust M) has anyone used a 25mm hubcentric adapter to achieve fit in an application like this?
It would put me at the fitment limit of 20x9.5 but i havent seen to many write ups on this, any advice would be appreciated.
05GTNYYNYG is offline   Reply With Quote
Old 03-25-2015   #2
On Edge's Avatar
Liked: 1015 times
NYM Trader: 8
On Edge's latest status update: Happy New Year everyone !! It's going to be a great year !!
Default Re: Brembo brakes hubcentric spacers??
I ran into a similiar problem.
25mm spacers for the front might be alot, causing the font set up to stick out too far, and not looking good.
As a mock up, go to the hardware store and buy nuts that can fit over your lug nuts. This will act as a spacer ( probably about 3/4" )
If you want to get to 1", then add some washers.
By doing this you will see exactly what size hub centric spacers you need to buy.
They come in 1/2, 5/8, 3/4, etc ...
ROUSH 4 and FangStang like this.
AHRC CarShow-Fundraiser.
On Edge is offline   Reply With Quote
Old 03-25-2015   #3
Liked: 125 times
mustangted's Pictures
mustangted's latest status update: not sure why I brother coming here, 99 prevent of posts have norhing to do with mustanfs
I doubt the studs are longer enough for a 25mm spacer
mustangted is offline   Reply With Quote
Old 03-25-2015   #4
Liked: 125 times
which is basicly 1 inch
Old 03-26-2015   #5
05GTNYYNYG's Avatar
this sounds like a plan,im hoping that I can get away with 1/2 or 3/4 because I already run 20x10 in the rear and being flush or more with my drop/stance now will not be attainable (Id have to bring up the front,not a fan of the look)
Old 03-26-2015   #6
On Edge's Avatar
Liked: 1015 times
NYM Trader: 8
Like mustangted said,
Always be safe and make sure your studs are long enough for the spacers.
When you add spacers, you are losing the amount of lug threads that your lug nuts are grabbing.
also, when buying longer studs, make sure you buy the right ones for front or rear.
On my car there was a difference.
Old 03-26-2015   #7
On Edge's Avatar
Liked: 1015 times
NYM Trader: 8
also, when buying longer lug studs, make sure you buy the right ones for front or rear.
Old 03-26-2015   #8
Authorized Vendor
Matt@RealSpeed's Avatar
Liked: 190 times
Matt@RealSpeed's Pictures
Matt@RealSpeed's latest status update: 2014 GT Getting some love from Vortech today at Realspeed
If your going to go with longer studs give me a call and I can assist you in picking out the correct thread and knurl size.
FangStang likes this.
Matt@RealSpeed is offline   Reply With Quote
Old 07-14-2015   #9
05GTNYYNYG's Avatar
So the end of the story was I had to replace the wheels, American racing changed the contour of the spokes and the depth of the hub to accommodate these brakes. FML! it got expensive in a hurry.
Posted via NYM Mobile
Search this Thread:
Advanced Search
Ford : Mustang GT 500 COBRA SHELBY GT500 COUPE SUPERCHARGED BREMBO BRAKES 6 SPEED 200 eBay Feed Mustangs on eBay 0 08-14-2012 11:56 AM
spacers, ceramic brakes, 3rd link bushing kit aks197 Modular Motor Parts (96 - 14) 2 10-13-2011 10:30 AM
Brembo GT500 brakes installed 2007 GT Convertible RedMOsesSC 2005 - 2010 10 12-07-2009 07:10 PM
WTB: 05-09 Shelby GT500 brembo brakes Xman037 Chassis / Suspension / Brakes 0 10-19-2009 06:46 AM
05-09 cobra brembo brakes complete! boostingwild Chassis / Suspension / Brakes 5 09-30-2009 08:01 PM
