not sure if this is allowed, trying to help my friend sell his car, after trading him for the chrome cobras and driving my car to his house, He has this has this oddly strong desire to sell his fox...... idk why...... lol
http://newjersey.craigslist.org/cto/4177150383.html
I am the second owner of this 117,980 mile 1989 Ford Mustang LX. It has always been adult owned. I bought this car from the original owner. He was also a customer of mine when I worked as a Ford Master Technician. The car is in good condition and highly modified. It is supercharged and a lot of time and money has gone into suspension and braking modifications in addition to everything else. It honestly turns and stops as well as my M3. It is set up with a stiff suspension and very aggressive brakes. It is also converted to manual brakes using the Maximum Motorsports kit. This provides consistent brake pedal feel although it requires more effort. If you are looking to sip your latte on the way to work while playing with your phone then this is definitely NOT the car for you. The car was tuned by Craig at Radical Racing in Jackson NJ. Due to my work schedule and the fact that I also have other vehicles I just don't have the time for a car like this anymore. I have every receipt from day one. All of parts were professionally installed, new, and only high quality components were used. The interior is in very good condition, all of the panels present and clean. The carpet shows normal wear for a 14 year old car. I'd rate the paint as 7 out of 10. The bumpers and side moldings have been repainted white to match the rest of the car. The rest of the paint is original. There are a couple of small door dings in the left and right rear quarters. The paint still has a good shine when washed and waxed. There is a very small amount of rust under the right corner of the hatch but it is very minor and has not spread. There are also a few chips in the rear spoiler that have been touched up. This seems to be very common with any Fox Body Mustang that I've ever owned. The only other thing that I can think that the car can use is a retune. The cold idle is choppy and surges when cold but much better when the engine is hot. Once it is warmed up it won't stall. There is also a small part of the tune that needs to be smoothed out where it transitions from stock map to stand alone. I was never happy with the driveability of the original tune at part throttle. It seems as if the tuner focused more on making power at wide open throttle. I would also recommend a larger supercharger pulley to reduce the boost a few pounds. Other than that the car is flawless. If you are looking for a clean, fast Fox then this may be the car for you. Most of these are beat by now. This car has been garage kept and is solid. I've priced this car to sell fast. I have seen many other cars not nearly as nice as this one going for more. The parts total alone is much more than the selling price. I'm sure that I'm leaving out something. So much has been done to this car over the years. Please respect my time, if you are not in the market to buy a car like this. Feel free to contact me with any questions or concerns thank you. Call: nineseven three 4seven7 five73five or e-mail.
Modifications:
Engine
Trick Flow Heads, Cam (stage 1), Intake Manifold, 1.6 Roller Rockers and Valve covers. Vortech S-Trim V1 Supercharger w/ 10-rib pulley (14 lbs. boost), AFM Power Pipe, Under drive Pulleys, BBK Shorty Headers (unequal length) w Copper Gaskets and ARP Hardware, Bassani Catless X-Pipe, Magnaflow Stainless 2.5" Exhaust w Dumps (Will Include Tailpipes w 3" Tips, Never Installed), New Radiator, A/C Delete, Accufab 75mm Throttle Body and Spacer w/ EGR delete, Smog Pump Delete, Solid Engine Mounts
Ignition/Fuel/Electronics
MSD Street Fire Ignition, Distributor, and Plug Wires. Anderson Ford PMS Piggyback Engine Management w 3-Bar MAP Sensor, 130 Amp Alternator, 60 lb. /hr. fuel injectors, Pro-M Mass Air Flow Sensor, Vortech T-Rex Pump, 255 lph in-tank Holley fuel pump, Battery Relocated to Back, Electric Fan w Adjustable Control, Kirban Adj FPR., High Torque Mini Starter, Alarm System w Keyless Entry Remote
Chassis/Suspension/Driveline
Weld-In Subframe Connectors, Tokico 5-Way Adjustable Dampers, Poly Isolators, Eibach Springs, Maximum Motorsports Panhard Bar, Rear Lower Control Arms, Aluminum Rack Bushings, U-Joint Steering Shaft, Caster/Camber Plates, Adjustable Clutch Cable w Firewall Adjustment, Boxed Rear Upper Control Arms, Ford Racing Aluminum Drive Shaft, McLeod Clutch, Steel Braided Brake Lines, Cobra Brakes, Front Slotted Rotors, Hawk Pads, Adjustable Proportioning Valve, Manual Brake Conversion w 93 Cobra R Master Cylinder, Steel Input Shaft Bearing Retainer, Pro 5.0 Shifter, 17x9 Black 03 Cobra Style wheels, 255/45/17 front and 275/40/17 rear tires, 3.55 rear ring and pinion, Ford Racing Rear Diff Cover w Cap Supports, North Race Car Rear Axle and Caliper Relocation Brackets (Allows use of wider rear tires/wheels)., Polyurethane Trans Mount, Polyurethane Sway Bar and End link Bushings
Interior
Pioneer Head Unit w CD/Mp3/WMA, Auto meter Phantom Series Gauges (Wide Band A/F, Tach, Water Temp, Voltmeter, Boost/Vacuum), White Face Gauge and HVAC Overlay, Ford Racing Shift Boot and Knob, Armrest Delete, Grant Steering Wheel, Window Tint (Lighter in Front, Darker in Rear).
Modifications:
Engine
Interior
