Old 12-12-2008   #1
Senior Advisor
1QWKVERT's Avatar
Liked: 14 times
1QWKVERT's Pictures 1QWKVERT's Garage
1QWKVERT's latest status update: Im backkkk!!
Default 5.0L Tech
Post up any tech info you got
Base Idle Reset Procedure
1. Clean TB with carb cleaner and nylon brush (toothbrush size). Engine off, fully open TB blade and spray/brush TB until all gunk and oil residue is cleaned.
2. Allow to dry, or close TB blade and start engine until it clears all carb cleaner fumes/liquid.
3. Let engine idle...if it doesn't, increase idle speed via TB stop screw until engine stays idling on its own.
4. Disconnect IAC valve, if engine dies repeat 3 with IAC disconnected.
5. Set idle speed to the lowest setting possible between 650-850 rpms with IAC disconnected. It is key to use the lowest possible to prevent idle surge, rolling, etc once the IAC is connected as follows.
6. Turn engine off, and reconnect IAC
7. With Ign On Eng Off, check TPS voltage output....if it's between .8vdc - 1.0vdc, it's OK. This voltage check should be done between the Green and Black wires at the TPS side connector as shown in the pic below (FYI: Green = TPS Signal, Black = SIGRTN, and Orange = VREF)....(-) terminal of the DVOM on the Black wire and (+) terminal on the Green wire.
8. Disconnect battery (-) for 3-4 minutes.
9. Reconnect battery, start engine, allow it to idle for 2-4 minutes to confirm setup,
10. If idle speed falls too low or stalls, increase idle speed via the TB set screw a little at a time.
11. Turn engine off for 20 seconds, re-start engine and repeat 9 - 11 if required.
12. Reconfirm TPS output is within the .8vdc - 1.0vdc range optimum range.
NOTES:
1. No need to reset ECM KAM (reset computer), the TPS minimum value used for idle control, is reset automatically by the EEC-IV every time the ign is cycled on-off for 20 seconds-on.
2. If the TPS output is within 6vdc - 1.1vdc, it's still acceptable, since no TPS failure codes will be generated, and it falls within the EEC-IV .5vdc - 1.19vdc working range.
13. Allow a 10-20 minute "relearning" period under normal driving conditions (drive cycle).....you're done!
1QWKVERT is offline   Reply With Quote
Old 12-12-2008   #2
Senior Advisor
1QWKVERT's Avatar
Liked: 14 times
Default
ENGINE EXPLOSION
CYLINDER HEAD TORQUE SEQUENCE
TIMING AND FIRING SEQUENCE
SERPINTINE BELT
5.0L Torque Specs
Belhousing to engine bolts 28-38 ft/lbs
Camshaft sprocket bolt 40-45 ft/lbs
Camshaft thrust plate to engine block bolts 108-144 in/lbs
Crankshaft pulley to vibration damper bolts 35-50 ft/lbs
Cylinder head bolts
-1979-1992
--Step 1 55-65 ft/lbs
--Step 2 65-72 ft/lbs
-1993-up
--Step 1 25-35 ft/lbs
--Step 2 45-55 ft/lbs
--Step 3 75-85 ft/lbs
Differential shaft lock bolt 15-30 ft/lbs
Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs
Exhaust manifold bolts 26-32 ft/lbs
Flywheel mounting bolts 75-85 ft/lbs
Front engine mount nuts 72-98 ft/lbs
Intake manifold to head bolts
--Step 1 96 in/lbs
--Step 2 16ft/lbs
--Step 3 23-25 ft/lbs
Intake manifold (upper intake to lower) 12-18 ft/lbs
Oil filter insert to engine block adapter bolt 20-30 ft/lbs
Oil pan mounting bolts
-1979
--Step 1 (Large bolts) 11-13 ft/lbs
--Step 1 (Short bolts) 7-9 ft/lbs
--Step 2 (Large Bolts) 15-17 ft/lbs
--Step 2 (Short Bolts) 10-12 ft/lbs
-1980 to 1987 9-11 ft/lbs
-1988 to 1993 6-9 ft/lbs
-1994-up 110-144 in/lbs
Oil pickup tube to main bearing cap nut 22-32 ft/lbs
Oil pickup tube to oil pump bolts
-1979 to 1987 10-15 ft/lbs
-1988-up 12-18 ft/lbs
Oil pump mounting bolts 22-32 ft/lbs
Pinion bearing preload 8-14 in/lbs
Pressure plate to flywheel bolts 12-24 ft/lbs
Rocker arm fulcrm bolts 18-25 ft/lbs
Spark plugs 7-14 ft/lbs
Timing chain cover bolts 12-18 ft/lbs
Vibration damper to crackshaft bolt 110-130 ft/lbs
Wheel lug nuts 85-105 ft/lbs
Old 01-13-2009   #3
King Mustang's Avatar
Default
Good info
AJ'S PERFORMANCE
Imports are like tampons every pussy has one.
King Mustang is offline   Reply With Quote
Old 01-14-2009   #4
NYGT's Avatar
NYGT's Pictures
Default
Yeah that's some real good info guy's.
NYGT is offline   Reply With Quote
Old 04-04-2009   #5
Flavadave's Avatar
Liked: 1 times
Flavadave's Pictures
Flavadave's latest status update: wanting to sell the 'vert
Default Re: 5.0L Tech
Courtesy of Wicked extreme, courtesy of PRO-M
The Facts about Mass Air Flow Meters
Size Does Matter!
If you have an engine that makes enough horsepower to warrant larger injectors, you will need to complement it with a Mass Air Flow (MAF) meter that is not only properly sized, but properly calibrated as well. If the MAF meter is not large enough, it will become a restriction in the intake path and will limit the engine's overall horsepower potential. If the meter is too large, it can loose resolution, and accuracy. You should choose a meter that is sized appropriately. Of course, we can help you make the proper decision. Below is a list you will find helpful.MASS AIR METER Horsepower Level
55mm (Stock 88-93 Mustang) 275 HP
70mm (Stock 94-95 Mustang) 350 HP
75mm Pro-M Bullet 550 HP
80mm (Stock Ford) 450 HP
Pro-M 85mm Flanged 650HP
Pro-M 95mm Flanged 750HP
80mm Pro-M 800 HP
92mm Pro-M 1500 HP
Calibration
The MAF meter's calibration is equally important. In fact, having a properly calibrated mass air meter is the single most important factor that should be considered when choosing an aftermarket MAF meter. The meter should be calibrated to match the flow rating of the fuel injectors, in conjunction with the PCM (engine computer) being used for the given application. A properly calibrated MAF meter will result in a meter that generates an accurate voltage signal vs. the air mass entering the engine throughout the entire RPM range of the engine. If the meter you are using is not properly calibrated, the meter may "peg" (reach maximum voltage output) before the engine reaches maximum airflow, which will result in an inaccurate air/fuel ratio, causing a loss in horsepower, or even potential engine damage. In contrast, it may fall below the PCM's expected minimum voltage input at idle speed, which will result in the PCM entering a "failure mode", which will cause a very rich condition at idle. A properly calibrated MAF meter ensures that the PCM receives a correct signal throughout the engine's entire operating range, resulting in a proper air/fuel mixture, maximum horsepower, excellent drivability, and maximum fuel economy.
There are various methods currently being used in the aftermarket to recalibrate MAF meters. There is only ONE correct method. These methods are as follows:
One method being used manipulates the voltage signal from the MAF meter by mechanically changing the amount of air that is permitted to pass by the filament of the meter. This is done by installing a different size sampling tube, or by restricting the flow through the tube with a screw. While this method can result in a voltage vs. air mass reading that is usable by the PCM, it is not possible for it to be correct throughout the entire RPM range. This WILL result in some form of drivability concern. These are commonly reflected as idle problems, loss of power, and poor drivability & fuel economy. Expensive and time consuming dyno time is highly recommended with this type of meter, and the results are not always consistent.
There is also a method of introducing a "MAF Tuner", which is usually some type of in-line electronic device which is intended to vary the voltage output of the mass air meter to extend the range or allow the use of a MAF meter that has not been properly calibrated. These devices will require dyno tuning to work properly, because the MAF "curve" does not match that of your PCM. Since no transfer function information is available when using these devices, expensive and time consuming dyno time is an absolute must!
There is also the option of using a meter that has not been calibrated at all, or is not properly calibrated. See "Buyer Beware" below. Commonly, these meters have a generic curve that may, or may not operate within the appropriate range of the engine. These meters will require dyno tuning to work properly, because the MAF "curve" does not match that of your PCM. Since no transfer function information is available when using these meters, expensive and time consuming dyno time is an absolute must!
The final, and BEST, method for calibrating a MAF meter is to change the MAF meter's voltage output by manipulating the electronics of the meter itself. This is an extremely accurate way to calibrate a meter because the meter's "curve" can be precisely targeted to reflect the needs of the new application. Pro-M Racing was pioneered in 1988 by Bob Atwood, a Ford engineer who was instrumental in developing mass air technology. Not only is this method based upon OEM techniques, this is truly the ONLY way to PROPERLY calibrate a mass air meter. Pro-M is the only aftermarket company with both the intellectual and physical properties necessary to properly calibrate your mass air meter. In order to properly calibrate a meter, you need to know the baseline "curve" of that meter. Quite simply, we are the only aftermarket company in possession of this information.
As an added bonus, All Pro-M meters are supplied with a transfer function sheet. This is the air mass vs. voltage data for your particular mass air flow meter. This is invaluable information for anyone who desires to have their PCM professionally tuned. It allows the tuner to have the EXACT air mass vs. voltage data for your meter, resulting in a perfectly accurate reading by your PCM. No other method of calibration will provide you with this important information. Lack of this information will result in a "tune" that is, at best, an educated guess.
Buyer Beware !
Some people will say anything to get you to buy their products. These people will very carefully word their advertising to mislead you into thinking they are able to calibrate a meter to suit your needs. Make sure you educate yourself about their abilities before you buy! This is actually quite easy to do. Ask them to recalibrate your existing meter. If they can't, or if they say they can, but won't do it for you, then they are not calibrating their own meters. These people are selling meters with generic curves. They will require dyno time.
Repeatability Vs. Accuracy
If you have ever been MAF meter shopping, you have likely heard the term "repeatability". Repeatability simply refers to how close one meter's calibration is to the next one. In other words, if you had a batch of 100 MAF meters, could you substitute any one of these meters for any of the others and have the same result? If you can, then the meters are "repeatable".
However, repeatability is often confused with accuracy. Accuracy refers to how close the meter's calibration is to the required calibration. Those same 100 meters could be 100% repeatable, and still be very inaccurate. It is much more important for a meter to be accurate, than it is for it to be repeatable. When you have accuracy, you have repeatability. However, when you have repeatability, you do not always have accuracy.
At Pro-M Racing, we individually calibrate our meters to be extremely accurate, AND repeatable. It's all in the calibration. We base our calibrations on the original OEM manufacturer's baseline specifications. NO OTHER aftermarket MAF meter manufacturer is able to make this claim! Other companies compare their calibrations to actual production MAF meters, which typically have a tolerance of (+ or -) 4 to 6%. When you add this to other manufacturers accepted method of recalibrating MAF meters, you could potentially end up with a meter that is as much as 10 to 15% off the desired target, and yet still checks out fine by their standards. All PRO-M MAF meters are held to within (+ or -) 2% of the original manufacturer's specification - This is a tighter tolerance than is even available with an OEM MAF meter!! Our most popular meters, the "Pro-M 80 and Pro-M 92", can actually hold a tolerance as close as 1%. Quite simply, our combined experience and manufacturing methods insure that you will get the best MAF meter that your money can buy. No one else even comes close.
1989 Mustang GT
1988 Mustang LX- For sale
Flavadave is offline   Reply With Quote
Old 10-16-2009   #6
TheWhiteFox's Avatar
TheWhiteFox's Pictures
here are casting numbers and years for 5.0 blocks seems a common question
D8VE= YEAR 1979,80,81 WEIGHT 135lbs.
E0AE= YEAR 1982 WEIGHT 120lbs.
E2AE= YEAR 12/01/1982,83,84 WEIGHT 120lbs.
E5AE= YEAR 1985 WEIGHT 122lbs.
E6SE= YEAR 1986-93 WEIGHT 126lbs.
if it wasn't for us slow people, there wouldn't be any fast ones...
TheWhiteFox is offline   Reply With Quote
Old 01-06-2011   #7
5.0 Moderator
dsblk93gt's Avatar
Liked: 227 times
NYM Trader: 5
dsblk93gt's Pictures
dsblk93gt's latest status update: having Vortech withdrawals
some weights of common parts including wheel weights I found online
stock 87-93 K-member 58 lbs
stock 87-93 A -arms (each) 10.5 lbs
stock 87-93 spindle, strut, brake rotor and caliper (one side) 56 lbs
stock 87-93 8.8 rear axle drum to drum 183 lbs
stock 94+ 8.8 rear axle with brakes 199 lbs
stock 87-93 front spring (each) 10 lbs
stock 87-93 rear spring (each) 9 lbs
stock 87-93 seat (LX - each) 36 lbs
stock 87-93 rear lower control arm (each) 7 lbs
stock 87-93 rear upper control arm (each) 3 lbs
stock 87-93 heater assembly 28 lbs
87-93 sound dedner 22 lbs
87-93 tar paper 23 lbs
stock 87-93 master cylinder 8 lbs
stock 87-93 battery 42 lbs
stock 87-93 driveshaft 19 lbs
87-93 wiper motor and arms 6 lbs
87-93 rear bumper support 31 lbs
87-93 front bumper support 23 lbs
87-93 center console arm rest/change compartment 8 lbs
87-93 door crash braces (each) 18 lbs
Factory 92 and newer high torque starter 7 lbs
87-93 Smog pump & emissions equipment 10 lbs
87-93 Fog lights & mounting brackets (each) 2.5 lbs
90-93 air bag steering wheel 9 lbs
Ford Racing 351 ALUMINUM RACE BLOCK M-6010-C451* Billet Steel Main Caps 92 lbs
GM LS1 engine with all accessories and flexplate 457 lbs
GM LS1 engine with all accessories, flywheel and clutch assembly 492 lbs
AJE 87-93 chromoly K-member 16 lbs
QA1 87-93 K-member 26 lbs
AJE 87-93 drop spindle (each) 9 lbs
AJE 87-93 tubular adjustable A-arm (each) 5 lbs
AJE 87-93 coil over strut and spring (each) 10 lbs
87-93 8.8 narrowed .75 on each side with Mark Williams 35 spline gun drilled axles, spool, yoke, Aerospace brakes, bracing, coil over brackets 182 lbs
QA1 rear coil over shock and spring assembly (each) 8 lbs
87-93 Aerospace front brake assembly (each) 14 lbs
Mickey Thompson ET Front 26x4.5-15 (each) 12 lbs
Mickey Thompson ET Drag 28x10.5-15 (each) 23 lbs
Summit plastic drag bucket seats (each) 12 lbs
Aerospace 87-93 Mustang master cylinder kit 3 lbs
Optima 8022-091 Battery 35 lbs
Ford Racing aluminum driveshaft for 87-93 14 lbs
Grant GT steering wheel with quick release adapter 3 lbs
17x9" AFS CobraR 95 chrome 24 lbs
17x10.5" AFS CobraR 95 chrome 26 lbs
17x9" AFS 03 Cobras chrome 27 lbs
17X10" AFS 03 Cobras chrome 29 lbs
17x9" AFS 03 Cobras satin 26.1 lbs
17x10.5" AFS 03 Cobras satin 26.5 lbs
18x9" AFS 03 Cobras satin 25.5 lbs
18x10.5" AFS 03 Cobras satin 29.1 lbs
17x9" BBS Spider 21 lbs
15x3.5" Bogart drag-on fly star 9 lbs
15x7.5" Bogart Classic Star 10.5 lbs
15x8" Bogart Classic Star 11 lbs
16x7" 91-93 Mustang Pony wheel 23 lbs
17x8" Bullitt satin 28 lbs
18x9" Bullitt chrome 29 lbs
17x9" Cobra R 25 lbs
17x8" Cobra 96 satin 23 lbs
17x8" Cobra 98 satin 21 lbs
17x8" Cobra 99 satin 22 lbs
17x8" Cobra 99 polished 25 lbs
18x9.5" Cobra R 00 chrome 29 lbs
18x9.5" Cobra R 00 powerder coated 27.5 lbs
17x9" Cobra 03 satin 25.5 lbs
17x9" Cobra 03 10th anniv 23 lbs
17x11" Fikse 16 lbs
18x9" FR500 satin 26 lbs
17x8" GT 99 satin 17 lbs
17x8" Mach I 03 satin 25 lbs
18x9" Mille Miglia MM11-2's 25 lbs
18x8" SSR Integral 19.5 lbs
18x9" SSR Integral 20 lbs
17x9" Steeda ultralights satin 21.5 lbs
17x9" Steeda ultralights chrome 24 lbs
18x9" Steeda ultralights satin 22 lbs
18x9" Steeda ultralights chrome 24.5 lbs
15x3.5" Weld draglites 10 lbs
15x8" Weld draglites 13 lbs
15x10" Weld draglites 14 lbs
15x8" Weld Rodlites 13 lbs
15x3.5" Weld pro-stars 10 lbs
15x8" Weld pro-stars 12 lbs
15x10" Weld pro-stars 14 lbs
15x4" Centerline Convo-Pro 9.5 lbs
15x8.5" Centerline Convo-Pro 12.5 lbs
15x4" Centerline Tel-Stars 12 lbs
15x8" Centerline Tel-Stars 16 lbs
15x7" 99 V6 Mustang wheels 14 lbs
17x9" Wheel Replica Bullitts 23 lbs
17x9" Wheel Replica Bullitts chrome 24 lbs
17x10.5" Wheel Replica Bullitts chrome 25 lbs
16x7" Crown Vic oem wheels 25 lbs
18x8.5" BBS RK (Silver) 19 lbs
18x10" BBS RK (Silver) 20 lbs
16x7" GT Waffle wheels 19 lbs
17x9" Konig Villain wheels 21.5 lbs
2011 Shelby GT500 ex Ford press vehicle- Race Red SVTPP & electronics package, Roush axleback, resonator delete, MGW shifter - 11.91@120 1.93 60ft
1993 Mustang LX 5.0 - Vortech Si-Trim, Edelbrock heads, Cobra intake, 60lbers, BA2400 meter, and a whole lot more...11.91@123.5 in 100% street trim SOLD!
2005 BMW 545i 6spd manual - Alpine White, Sport Package~ Daily Driver - 13.33@107
dsblk93gt is offline   Reply With Quote
Old 01-07-2011   #8
MIKE88's Avatar
Liked: 15 times
MIKE88's latest status update: is a retired svtsnake admin
awesome list of different weights, thankyou.
white 93 notch
MIKE88 is offline   Reply With Quote
Old 01-07-2011   #9
5.0 Moderator
dsblk93gt's Avatar
Liked: 227 times
NYM Trader: 5
No problem! I will see what other ones I can find as well.
Old 01-07-2011   #10
AdirondackFox08's Avatar
Liked: 491 times
AdirondackFox08's Pictures AdirondackFox08's Garage
AdirondackFox08's latest status update: Woohoo! Kevin Harvick and the #4 team won the race and the championship!!! What a great...
I didn't realize the aftermarket K members were that much lighter... good info Dave!
1990 Mustang GT - H/C/I, 3.73s, 292rwhp & 320rwtq
2009 Cobalt SS - G85 package, ZZP down pipe
1999 Polaris XC 700 - Winter toy
AdirondackFox08 is offline   Reply With Quote
Search this Thread:
Advanced Search
Engine Tech 1QWKVERT General Tech 2 06-30-2018 07:49 PM
