3.73 are a comfortable enough street gear for an auto. for a 5 speed, 4.10s are recommended. but that is if you want a much faster car. id stick with the 3.73s. as for the install, make sure you have everything you need. (rear end rebuild kit) because as long as you are in there you might as well freshen everything up. new bearings, spacers, etc... it also makes the install easier. as for the speedo gear i think you may need a 23 tooth but dont hold me to that. check with ford racing.
